190xt
Donkeyboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkeyboy Quote  Post ReplyReply Direct Link To This Post Topic: 190xt
    Posted: 11 Feb 2020 at 6:12am
Need help.Head redone,rebuilt pump,rebuilt injectors,timing at 26dg btdc,extremely hard start with tons of gray smoke,no priming pump has inline electric and plenty of fuel.
ebowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ebowman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 6:35am
how does it run after you get it going? rough at idle? smooth at high idle? What would happen to be the temperature when trying to start? Air intake heater used or working?
WD45, '62 D17 Diesel, '65 190XTD, '74 7030, 1958 Roto-Baler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkeyboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 6:39am
It’s in my shop 70degrees,once it starts it’ll restart fine.Smoke clears up it purrs.Wont start without either over night.I have no leaks anywhere.Did a compression check 160-180 through all cylinders
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkeyboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 6:41am
2/6 had a miss fire on initial start up with the exhaust manifold off but cleared up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:10am
Cranking compression check with all injectors removed should be 350 psi or more. "Going thru the head" means grinding valves/seats ?? and when the valves are sunk into the head more than the .040" allowed by specs they will start hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkeyboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:13am
It got all new valves guides and seats.My book showed head bolts 150 ft lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:17am
But how deep are the valves below flush of the cylinder head surface ????????????? Grinding the old seats just sinks the valves deeper, which lowers the compression. I can't believe you only have 160-180 psi of cranking compression. How did it start BEFORE you worked on it ??? Why was the head removed??   Has the inj pump been removed and reinstalled??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkeyboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:32am
I will have to call the machine shop on the valve seats there all new.Head was removed because it leaked oil out the intake side. I ran it all last year on a round baler gray smoked like crazy so sent the pump and injectors out for a rebuild.Started fine lastyear.Maybe I need to do a recheck of compression but I’m pretty sure its correct.4700 hours maybe it’s time for rings
Post Options Post Options   Thanks (0) Thanks(0)   Quote ebowman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:33am
When I overhauled mine last winter, the machine shop had to replace my valve seats in my head due to the fact the seats were in the head too far. He asked me if any work had been done on head before. Of course I didn't know.
My point is that machine shops don't always get things correct. Now she fires up at 20* without being plugged in.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:37am
Who did the pump work? I've seen some really poor work out there, and the timing mark could be way off inside the pump. Did they rebuild your pump, or exchange? Like Dr asked, how did it run before? After reading this, it almost looks to me like you're confusing compression testing, with head bolt torque. Maybe I just mis-read. Compression testing involves removing all 6 injectors, and putting a dummy injector test adapter in one cylinder at a time. AC books called for running comp test, but that is much more difficult. Extremely low compression from stuck rings will cause it to smoke white like crazy, and require ether to get started and even keep running on ether until it gets some heat into it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ebowman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:45am
Hard starting when cold, starts fine when warmed up.........
Sounds like low compression or fuel bleeding off.
From his description I would say low compression. either in the head or in the rings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkeyboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 8:08am
The pump went to Kansas a friend of mine sent it out there. I’ll do another compression check tonight I believe I left the injector copper rings in when I did it.And once again check my timing.Im about to pull the pump and have it locally checked.3k in parts and worse off than started ugh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 8:10am
A warn pump head or leaking delivery valve will cause poor start and a lot of white smoke. Advanced timing will also cause the same thing.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkeyboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 8:34am
The pump was supposed to have been ( rebuilt )
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 8:45am
To compression test, you need to use a copper washer like on the injector, just reuse the same one. Just needs to seal off the chamber. As Dr said above, a diesel engine should have at least 300 psi cranking, 350-400 is better. The higher it is, the better it will start at colder temps. I cannot believe grinding valves and sinking the height could lose 200 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ebowman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 8:57am
If you going to take the pump somewhere send it to InjpumpED. I wouldn't trust anyone in Indianapolis
This page was generated in 0.146 seconds.
