Wheel hub conversion |
Burl
Silver Level Access
Joined: 13 Sep 2014 Location: Aurora Mo. Points: 232 |
Topic: Wheel hub conversionPosted: 25 Jan 2020 at 8:13pm |
I always have to make things difficult .Has anyone tried to find conversion bearings so a D15 or WD - D17 front wheel hub would fit on a B spindle ? I could cut out rim centers and weld to outer rims but this hub change out would be slick if its possible.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 25 Jan 2020 at 8:43pm |
Should be as easy as measuring the spindle on the B in the 2 places the bearings run, and measuring the bores in the hub you want to use. Then take your measurements to your local bearing supply company. Motion Industries probably has a bearing that will work.
Burl
Silver Level Access
Posted: 25 Jan 2020 at 9:18pm |
That was my plan B . Was hoping someone already done the homework , my luck, this research could be a real stinker to work-out . The local parts stores around here just wants you to hand them the part number . They are not much help sometimes.
MACK
Posted: 25 Jan 2020 at 10:08pm |
Look up bearing chart on web. MACK
festus51
Joined: 26 Mar 2017 Location: Osage City, KS Points: 1644 |
Posted: 25 Jan 2020 at 10:59pm |
Burl I see your problem you are down there in Redneck country! LOL
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 26 Jan 2020 at 5:39am |
The D10 industrial I have as a project has the larger WC, WD type 5 bolt hubs on it. I haven't had anything apart, although I'd guess that as the parts book shows the same spindles as a regular D10, that just different bearings will do what your're looking to do. I might swap them over to the one CA I have a loader on, if someone doesn't take this parts tractor off my hands.
CTuckerNWIL
Posted: 26 Jan 2020 at 6:48am |
Don't use a 'parts store'. Go to Motion Industries in Springfield, or Webb City. Or Springdale, Ar. https://www.google.com/search?newwindow=1&client=firefox-b-1-d&tbm=lcl&sxsrf=ACYBGNRklErDWoXExN-7Vikr5amAiQqaAg%3A1580042458556&ei=2ogtXovMIZLRtAb34pP4Cw&q=Motion+Industries+near+Aurora+Mo.&oq=Motion+Industries+near+Aurora+Mo.&gs_l=psy-ab.12...0.0.0.325278.0.0.0.0.0.0.0.0..0.0....0...1c..64.psy-ab..0.0.0....0.ltGLijNckOU#rlfi=hd:;si:;mv:[[37.71691842742861,-91.44053937656247],[35.95406565736276,-95.46153547031247],null,[36.840571233675576,-93.45103742343747],8] |
Burl
Silver Level Access
Posted: 26 Jan 2020 at 7:52am |
I will get shaft and hub sizes today and see what comes up tomorrow . What I have is a very early series 2 D12 . It has the lighter axle with hubs & bearings same as series 1 and B - C . If this works I can put a set of 16s that came off a D17. Lot easier to find weights for.
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 26 Jan 2020 at 10:21am |
Down load the multiple sections of the catalog from http:www.baumhydraulics.com. They search better than their on line stuff. They have a good selection of bearings and of wheel hubs and wheels. They are in Omaha.
Gerald J. |
Burl
Silver Level Access
Posted: 26 Jan 2020 at 3:52pm |
Well , this project is over. Worked out bearing issue but , spindle shaft is to short (approx 7/8") to accommodate larger hub. Guess that why no one has already tried it. Poop!!
TimCNY
Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
Posted: 26 Jan 2020 at 3:57pm |
Better to go through to the end, than to give up before every possibility is exhausted. Good on ya, Burl!
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
john(MI)
Posted: 26 Jan 2020 at 6:44pm |
I've never been that deep, but how does a spindle attach? Couldn't you just change the spindles?
Burl
Silver Level Access
Posted: 26 Jan 2020 at 7:03pm |
It would be very costly ! The cost of larger spindle, bore out knee (tube spindle slides in ) or replace entire front axle with later model.
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Posted: 26 Jan 2020 at 8:16pm |
Is there enough room between the small end of the B spindle and the outer bearing bore of whatever hub you want to use to make a stepped nut that is threaded to serve the same purpose ? |
Burl
Silver Level Access
Posted: 26 Jan 2020 at 8:50pm |
That might work but, outer bearing is on some of threaded end and that makes to much clearance between the two surfaces. Kinda loose !
john(MI)
Posted: 27 Jan 2020 at 12:55pm |
Metal lathe time!
