Granpas D15
jollymon68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Topic: Granpas D15
    Posted: 21 Jan 2020 at 8:51am
Finally started the work on my grandfathers D15 diesel series I. She looks like a boat anchor now.
Removed the 20 year old diesel from the tank....wow that was disgusting. Found three mice nests one in the bolster, one in the radiator and one in the battery box. The black stuff in the tub is the diesel fuel.
Any tips on removing the stuck injectors? Let the fun begin!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 8:55am
Is the engine stuck?? or free ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 8:57am
Oh the engine is stuck, was free and running when she was parked, but that was some time ago.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 9:02am
Learned something new I always thought the motor was like a D19 only with 4 cylinders with the water pump on the block not the head.Not like the older Buda motors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 9:07am
I never worked on an older buda, but I have 3 series I D15 diesels so I have a bunch of great reference material. Grandpas tractor is completely original minus some brackets on the axle housings.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 9:31am
I'm thinking yo'll find a 4th 'mouse house' int he bell housing !! Mine was STUFFED ! took 3 HOURS to remove the 'condo'...starter was JAMMED from 'donations'.....
NICE project, family tractor.
 Take LOTS of pictures along the way and relax..have fun with it !!
Jay
smokechaser View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote smokechaser Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 9:46am
The injectors should come straight out, a tire-mans "J-bar" (its used to separate the lock rings on multi piece rims) is about the right shape to get behind them if they need a little help.
A-C HD5G, HD3, I600, WD-45; IH 424, B414, B250, Cub; Oliver OC6; Clark R60; Bungartz T5; Ferguson TO-20; MH 44
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 10:37am
Jollymon68,
 I will be watching! Not that I have any diesels. But your tractor looks like it was setting next to my friend Matt's D14!
I have never seen a air box rusted out like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 10:50am
I will keep everyone updated. The air cleaner rusted out because grandpa lost the top to it and let it fill with water. Here is a picture of one of my restored D15's
ACinSC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 11:42am
You did a great job on that tractor ! I'll be following this as we have two series 1 D 15s . One of which is a diesel . Thanks for the pictures
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 8:09pm
We have a series II gas, wonderful tractor. Diesel would be a nice find. Good luck on your project, looks like you have a good start and its in the family.
EPALLIS View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 10:23pm
Yes, I have a D-15 Series I and II Gas. My all time favorite A-C tractors! I must say though this diesel you shared pictures of looks like a challenge. Thanks for saving it.    Good luck!
frnkeore View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 12:25am
I'll be following, too. I might get a few tips on the restoration of my D14, that I got 3 months ago.
I'll start on it, in the spring.
Edited by frnkeore - 22 Jan 2020 at 12:26am
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 2:09pm
If you need a wiring harness for that ole' girl when the time comes, let me know...
Steve@B&B
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 5:21pm
Jollymon68,
Must comment on your beautiful D15 D! Almost make you want to run out and buy one of those! I think if that were still made they would sell!
I can see you have the skills to get this next family tractor in like new condition too!
 Thanks for the pictures!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2020 at 9:38pm
The tear down continues... So far only two broken bolts
Edited by jollymon68 - 28 Jan 2020 at 9:50pm
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2020 at 9:49pm
That is a NICE job on the D15 you completed !! I know how much time and $ it takes to do one .
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 8:32am
That rack you have to store parts is a great idea!
