Allis Chalmers 160 hydraulics
Ooga68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ooga68 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 160 hydraulics
    Posted: 19 Jan 2020 at 8:58pm
my 160 lost all operations after changing hydraulic fluid.  upon checking I found that the long pickup tube comming from sump to line going to pump has come loose and fell away from block. My question , when I removed the tube it has a plumming check valve on the bottom. In my manual it shows nor says anything about a check valve there , no mention. is this an old farmer fix for bucket not leaking down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2020 at 5:32pm
If it is on the pick up side of the hydraulic pump, it is there to keep oil i n the pump so it is primed whenever you start the it. If it isn't there, the pump can drain out and lose prime.
