Allis 185 Hydraulic
Kenny L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L Quote  Post ReplyReply Direct Link To This Post Topic: Allis 185 Hydraulic
    Posted: 15 Jan 2020 at 7:16pm
When checking the Hydraulic level on a 185 should you screw in the dip stick our just set it in the opening for proper level.I have a manual but unfortunately it doesn't specify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 7:46pm
I've always screwed it in,, seems the right way to do it- it seems like a poor design compared to the tranny fill, as dirt can fall into the hyd hole very easy
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 10:50pm
I'm with Doug, have always had it screwed in fully, wipe dirt away.
Ops Man'l says; Lower lift arms, fully retract any external hydr rams, run engine 3 minutes at high idle, shut off engine. Immediately remove dipstick and check oil level.
This page was generated in 0.305 seconds.
