262 gas in a WD45
ACD19farmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD19farmboy Quote  Post ReplyReply Direct Link To This Post Topic: 262 gas in a WD45
    Posted: 16 Aug 2010 at 8:02pm
Has anyone ever put a 262 gas or a diesel in a WD45 before?? and what changes will i have to make...other than the sheet metal, scootin the rad up, and linkage. The 262 that i am going to put in the tractor  is of a C Gleaner.
 Thanks, Cordel.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:16pm
 Thanks, Cordel.
Yeah they have... it really looks like something else:
http://pullac.com/
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:44pm
Hi Gordel, I have did it...my 262 is out of Gleaner C also. I am just finishing up the paint work and re assembling after completing the installation/conversion. In my opinion AC should have built a 45 with a six cylinder from day one..It runs so smooth and has big power!! 90plus horses! and sound sweet.
All you need is the following:
-45D adapter plate or use the adapter from the combine and use a 45D plate to drill your holes.
-45D flywheel or the flywheel from cockshutt 40 or 50 will work
-45D heavy spring clutch plate
-45D throttle linkage used to go to the injection pump and convert it to work with the governor
-D19 Governor or Cockshutt governor if you want it to run like a normal tractor
-45D rad or convert the 45Gas rad
45D hood
Some big rubber 16.9 or bigger!!!! I have 30's on mine of a 175 or 190 looks great!
That's about it enjoy.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD19farmboy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 9:13pm
Jim, could you take some photos of where you did the hook ups, it would be lots of help!
Thanks again, Cordel
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 9:20pm
Yes I will take a few photo's on the re-assemble and post for everyone. I also designed a dry element air cleaner set up for it.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD19farmboy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 9:51pm
This wouldn't happen to be you would it??
Cordel
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 8:25am
Not me that's me I am running a 262 gas with 18.4x30's and a single front wheel.
Jim
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 10:10am
There were two WD45s with 262 gas engines at the GOTO in Albert City last weekend and one 45 with a 301 diesel in it.   I didnt get any pictures, wish I had more time, 3 days just isnt enough!!!!!!!!
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 10:38am
Skip, I'vw got to agree with the comment that 3 days isn't enough time. I got home and realized that I failed to take hardly any photos of the tractors displayed. I did get some of the combining. raking straw and a few of the garden tractors working. While I thoroughly enjoyed myself, another day dedicated to only taking pictures would have helped. Guess that's why I like working shows though. You can get involved and are having so much fun you just forget to take pictures.  God Bless
This page was generated in 0.234 seconds.
