Allis 160
jollymon68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Topic: Allis 160
    Posted: 16 Dec 2019 at 10:39pm
Guys got an issue that has got me stumped. Replaced the head on my 160 and now im trying to find top dead center on number one cylinder to set the valves. Any suggestions or tips would be great
Wes (VA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 6:23am
Youll want to pull injector and watch rocker arms. When you rotate crank with a wrench, feel for compression coming out, both rockers should be loose when the air stops pushing out of the injector hole on #1 cylinder. There should be timing pointer to get it exact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 7:30am
Ok...I got everything bled. Now cannot get it to fire up. Running 400lbs of compression in all three cylinders but still nothing not even a puff of smoke. The head was replaced with a new one with the valves preinstalled. Fuel is going to the injectors but nothing. She ran before the head was replaced. Im not sure where I went wrong though. I think I have the timing right but cannot find a place to check the timing. Injector pump was never removed from the tractor either.
Edited by jollymon68 - 19 Dec 2019 at 7:33am
lowell66dart View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 7:33am
I have had a few 160's and they are one of the worst to bleed air out of. I plumb in a temporary inline pump to get it to start. They actually make one for diesel. Got it on Amazon.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 7:37am
Do you remember the name of the pump you bought
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 8:15am
If it's not smoking, it's not delivering fuel through the injectors. Whether it's out of time or not. If pump wasn't removed from engine, then it should not have gotten out of time all by itself. These have a 3 bolt drive gear with a dowel, and a chisel mark on the mountingflange of pump. So as long as the pump gear is in it's proper location, timing isn't your issue. As said above, CAV pumps can be tough to bleed. There is a bleeder screw right above the nametag. Takes a 5/16" wrench. If it still won't deliver fuel, the metering valve or pumping plungers could be stuck, and in that case it would be best to have it properly serviced. My bet is it has been a while since it last ran. Were injectors tested while head was off? I've seen people pull a head off and not pull the injector, and not even pay attention that the nozzle tips protrude through the head. Usually the tips get damaged and require injectors get rebuilt. If this is the case, the tips could all be smashed shut. Lots of issues possible here. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 8:31am
I did remove the injectors from the tractor before pulling the head. I had one replaced but the other I did not. I will get them tested but they were good when I took them off. I only replaced the one that was damaged due to me dropping a weight on it. the others were put in boxes by themselves. All the injector lines were delivering fuel to the injectors. When I hooked up the lines I get some spray of fuel around the injectors. I'll have to check the tips for any damage. Not a lot of diesel repair shops in my area unfortunately. Thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 4:57pm
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 7:05am
160 fuel system bleed procedure from the owners manual. When you try to manually pump the fuel lift pump handle and it doesn't seem like it is pumping, or has enough stroke to pump, rotate the engine some to get the camshaft eccentric off the high point.
I agree doing this a time or two, out in the field, trains you to watch the fuel gauge.
Edited by BrianC - 20 Dec 2019 at 4:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 3:01pm
Thanks OrangeC that is a much better picture for me to go by...
Post Options Post Options   Thanks (1) Thanks(1)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 4:52pm
I just updated my post, I had forgot to add the instructions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 9:50pm
Gentlemen thanks for all the help with the tractor. Was able to bleed the whole system thanks to OrangeC for the diagrams and instructions. Unfortunately that was not the issue with the tractor. Apparently when I removed the head I should have measured the height of the three head studs that are just under the injector connections. These were just a bit higher than the previous studs and they were preventing the injectors from completely seating. I ground the three studs down a bit, reinstalled the injectors and she fired right up. Now I gotta fix all the little fuel line leaks.
This page was generated in 0.223 seconds.
