B/C exhaust manifold
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Topic: B/C exhaust manifold
    Posted: 06 Dec 2019 at 3:31pm
Anyone remember the discussion about threading the exhaust manifold for installing a threaded pipe to aid in keeping rain out from running down the muffler? I think it was just a few weeks ago but I can't seem to find it. Thanks, Mike.
39B 42B 48C SFW 52Cub Cub Cadet 70 S14 Speedex M14 Speedex S18 Speedex
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 5:47pm
1 1/4 taper pipe tap for a 1 1/4 nipple.
Edited by Dick L - 06 Dec 2019 at 5:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 5:50pm
Easiest way to find things, is to type Allis Chalmers forum, followed by the subject you are searching, into Google, and search.  that's how I found this one:
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 6:07pm
I remember something about rain caps not keeping water out of manifold. And suggestions on tapping and a brazing, and a modification with exhaust piping.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 6:21pm
The threads help for a while, but eventually let water in! --- easiest way is to braze an upside down funnel above the manifold on the muffler pipe. --- did this on a 806 and a couple other tractors, does work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 6:51pm
That is why water pipes always leak right!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 7:05pm
if you thread the pipe into the manifold, and still get some water........... It is coming down the exhaust pipe thru the muffle......... the pipe thread don't leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 7:50am
Thanks guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 8:13am
I agree with ac fleet.  Not the easiest thing to do though.
I wonder, has anyone ever tried Gorilla glue to do this?  Can it withstand the high temp?
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 9:32am
My preference is to buy the OEM style of muffler which shields that area, then cover the exhaust pipe with a rain cap or can when left outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 9:43am
I did the shied over the manifold opening around the internal muffler pipe thing until I picked up my 1 1/4" taper pipe to see what size drill it would take to ream it out for the tap. I found it is cast to the correct diameter. All the Oliver's I grew up using came from the factory with a threaded pipe nipple that the muffler pipe slid over. The pipe nipple is a one time deal for the life time of the tractor with a (proper) rain cap. All my tractors set out year around and some only get started every couple years or longer. It is my insurance policy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 10:45am
Any idea what muffler number you use Dick?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 12:39pm
The one I use is a Ford inline under the red belly. I took a 1 1/4" nipple from their stock with me to the mufflers at Rural King and found one that fit and then put the nipple back. I cut and thread my own nipples at the factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 10:31am
Farmall Cubs use a threaded pipe into exhaust manifold.
This page was generated in 0.330 seconds.
