B steering problem
Cubfan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cubfan Quote  Post ReplyReply Direct Link To This Post Topic: B steering problem
    Posted: 26 Nov 2019 at 5:46pm
We were trying to move our 38 B today by hand (crank start but not today for some reason) and when turning the steering we heard a snap and then the wheel just spins.  I pulled it and it looks like there should be a woodruff key locking the wheel to the shaft.  Not sure where it went but it's gone.  Anyone know of a source for a new one or have a schematic of the steering wheel area?   Any help would be appreciated.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 6:01pm
If you talking about the steering wheel spinning it has a half round key.
this drawing might help.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 6:10pm
70905123 AGCO number I will help you if you need tomorrow if I can find sixe I will post it also
Albert
Ziegler AG 660 582 5150
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 6:24pm
3/16 x 3/4 woodruff key
Albert
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 6:33pm
local hardware store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cubfan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 7:23pm
thanks guys, I will try the hardware store tomorrow
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 7:29pm
My B did the same thing a couple years ago. It was the little stud on the "lever shaft" that rides in the worm gear. If yours is a 1938, it'll only have one stud, not 2 like in the picture above.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 8:36pm
If the nut holding the Steering Wheel on is tight, I doubt if it is the key.
Watch the nut and the end of the shaft and see if they turn with the wheel.
Gary
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 5:53am
Just proves what I have always said; A lot of the problem is the nut behind the steering wheel !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 3:13pm
This might have broke off or pushed back away it the steering wheel is turning the shaft,
I have never heard of the shaft separating from the worm but who knows without ex ray vision.
Edited by Dick L - 27 Nov 2019 at 3:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 9:23am
I just remembered buying a B with a ross steering box cover broke letting the shaft move the pall away from the worm. Something else to look for!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 10:30am
That pall will actually snap right off sometimes as well or wear out if someone put grease in the box instead of oil. I went through 4 boxes to build 1 good one for my B.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 1:13pm
Engine doesn't turn, AND steering is stuck?
Pull it into the shop, let it warm up for a day, then try it.  If they turn... drain the water out...
This page was generated in 0.050 seconds.
