D17 rearend leaking
Bob (mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (mo) Quote  Post ReplyReply Direct Link To This Post Topic: D17 rearend leaking
    Posted: 08 Nov 2019 at 1:56pm
My 1959 D17 has starting leaking hydraulic fluid out of the right brake housing hole. I am pretty sure its from the hydraulics because its the only one that is low on fluid (screwed in dipstick left of shifter). So how and what do i need to replace?
Thanks,Bob
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 3:02pm
Could be hydraulic cylinder inside of rear end for lift arms transferring hydraulic oil to rear end reservior. requires rear lift housing be removed to get at
Wink
I am a Russian Bot
This page was generated in 0.083 seconds.
