Allis 7060 670i rebuild help- piston
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7060 670i rebuild help- piston
    Posted: 05 Nov 2019 at 2:05pm
I have a black belly Allis 7060 with a 670i engine.  I pulled a damaged piston (from shattered exhaust valve) and found the number AP 307 cast into the inside.  Does anyone know the manufacture of this piston.  The tractor engine was rebuilt before my father purchased this by a John Deere mechanic so who knows what parts were used?  The piston ring location does not match the position of the after market pistons that I have seen?  Or the location of a piston from 7080 670Hi engine.  I need to get a replacement piston that needs to be the same one as this damaged one.  Any thoughts?
Edited by twinsonfarm - 05 Nov 2019 at 2:18pm
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 3:16pm
I Will Check Tomorrow For Used One That Was An M & W Piston I Had A Complete Kit Sold It The Other Year I Sold A Lot Of M&W Kits They Will Be Made Again Not Sure When
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 8:05pm
looks like its should have more rings, i see the oil control ring and maybe to compression rings. never worked on a 670I, maybe that's correct?
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 8:32pm
M&W pistons had a wide top ring that looked like a piece of angle iron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 9:22pm
If valves don't have a AC part # on them, I would replace them. Have saw after market valves fail before.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 7:36am
That makes sense as the broken exhaust valve had no markings....
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 8:23am
That is an M&W power seal piston. They use a high top ring land that is designed like the Dr. said. It improves the compression ratio slightly and makes for better cold weather starting. I'm not sure that they are available any more??
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 9:10am
Is it ok to put a reliance piston and sleeve into the No. 2 cylinder and leave the others that are not damaged alone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 10:22am
Countryside Tractor Has Used Ones Talk To Eli 717-923-0421
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 11:39am
Allis trained mechanic put a Reliance kit in my 8050 it made it 3 hours before it was apart again.   While it’s apart buy a complete quality kit and do it right.
200 10and20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 10and20 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 11:49am
Victory is right, why take a knife to a gun fight so to speak. It's a no win situation with only one off brand piston. Good luck either way.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 12:20pm
If it was mine I would at least take out the other pistons and inspect them. You have a lot of scoring and scuffing on the piston you have out and I don't think that is all from a dropped valve.  You may have other pistons in there with scuffing just like the one you have out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 1:11pm
I heard the factory burned and all tooling for those pistons was lost. Got a set in the 220 & 8070....will start below freezing with no aid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 2:48pm
Riley Tractor Parts  Will Have Them At A Later Date They Have The Tolling To Make Them I Just Talked To Them They Will Do The Allis Ones First I Am A Dealer For Riley
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 8:21pm
That's good news! They are awesome !
