FMJ Mag Help
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: FMJ Mag Help
    Posted: 04 Nov 2019 at 4:02pm
Working on getting my WC back running and have hit a snag.  Mags are magic as far as I'm concerned and I need some help.  Should I have continuity across the points when closed? I don't know if it's my multi tester or what, but I'm not getting any.  Plug wires show infinite ohms which would mean open circuit. I get about 4800 ohms resistance between the condenser side wire of the coil and the center lug. About 1.2 ohms between the 2 wires of the coil. Can't seem to test the condenser with a digital multi tester. Short of sending this thing to someone and spending a lot of money, what's the best course of action? Point/condenser and plugs/wires? Coil seems to test OK I think.  Not a lot of run time on the mag, but it's been 20 years since it went together.
AaronSEIA
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 5:04pm
Sounds like there are several wires disconnected in the magneto. The resistance at the points should be the primary coil resistance with the points open and zero with the points closed. Might be a sign that the points need a thorough cleaning.
I have a shop manual for FMJ at:
http://geraldj.networkiowa.com/Trees/FM-Xmagneto.pdf
Might not be the perfect match to your magneto but the findamentals should be similar.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 5:34pm
Take some TV tuner cleaner or Brakekleen and give a spritz to the points and run a rag through the contacts. Do this a couple times. Sounds like there's ozone or a film or corrosion on the contacts. Don't use a file, cause all that will do is remove the cadium plating from the contacts. The Cadium helps keep corrosion down. When they sit for a long time, they'll get a film on them and boom, no spark......
Steve@B&B
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 8:41am
You are showing your age Obiwan.  Do they still call it tuner cleaner in your area or do you just have a very old can?  Sorry, no pun intended.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 8:57am
How about Variable Pot, say that and you'll have every millennials attention within ear shot. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 9:37pm
An old timer told me once, he used a dollar bill to drag thru the points. Said there was enough dirt and grit built up on an older bill to polish them just enough. Then drag a piece of white paper thru to clean up any leftovers.
 With a digital meter, check ohms, then switch to voltage. The ohm meter should charge the condenser and when you check voltage, it should slowly drop off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 1:14pm
Guess I'm showin' ma' age Dave. They don't make TV tuner cleaner anymore?.....Still have a can of that on the shelf. Still works! LOL!!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 1:20pm
Charlie when you say, "With a digital meter, check ohms", where are you using the test leads, and are the points open or closed?
