Rear wheel assist gleaner
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Topic: Rear wheel assist gleaner
    Posted: 01 Nov 2019 at 11:47am
Which way do you have to have the dimple on the hub in or out for the hubs to be engaged to the motor? The dimple on my m3 are in, is this correct?
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 1:30pm
I thought on hubs like that, you had the dimple out.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 3:00pm
I believe dimple out is unlocked. I’ll look at mine tonight
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 7:13pm
Dimple is out on my R7. Should be engaged. Pushing in will disengage. Thats how a gilcrest is but it works a little different. Book says to keep engaged except when towing.
Edited by Daehler - 01 Nov 2019 at 7:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 7:38pm
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 8:54pm
Dimple out is engaged.      MACK
