D 17 LP
Deer hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deer hunter Quote  Post ReplyReply Direct Link To This Post Topic: D 17 LP
    Posted: 13 Aug 2010 at 8:53pm
Can an LP engine be converted to gasoline?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2010 at 11:09pm
Why would you want to convert it to gas?
 There are a few people like me that still want those tractors, why not just buy a gas one to start with? And let someone that wants an LP gas tractor own an origional.  the answer is yes... but you have to buy carb, hood panels, center strip and fuel tank and a few other misc. items.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2010 at 7:51am
Aside from the complication of refueling it, LP is just about the cleanest fuel you can run an engine on. They do have some collector value, so I'm with JC on this. Sell your LP tractor and buy an original gas burner.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2010 at 9:42am
Sounds like you are considering using an LP engine as a replacement? Should be as simple as changing to a standard gas manifold with a carb and throttle linkages.
Otherwise, I kinda agree I wouldn't convert a factory LP tractor if I could work a trade for a gas. That said, I wouldn't have an LP tractor myself and I can understand if you wouldn't either.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 7:57am
If you do convert it drop me a line I would be interested in purchasing the LP parts.
