D-19 Diesel engine swap?
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Topic: D-19 Diesel engine swap?
    Posted: 22 Oct 2019 at 11:01am
Hows much work is it to put a 301 in a d19 diesel? Our old motor is about shot and don't have $$$$ to rebuilt it. Uncle has a good 301 out of a 180 that he would give us.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 12:38pm
Even with a "free" engine, you're going to still spend some $$$$$ making it all work. If you are a narrow front end, forget it. There's no good way that I know of to connect the steering shaft and retain the power steering assist cylinder on the right side.  A wide front axle should be converted to hydrostatic power steering like the 180 is with an external cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 1:04pm
Yes its a narrow front! And we have a 190 picker on it. Dang! Was hoping it would work. May have to find a gas engine then. What about a 4 cylinder turbo engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 2:03pm
Currently doing an F-2 combine 4-cyl turbo diesel in a D-17 S3 with narrow front. I'm using a specific size Char-Lynn orbit motor connected to the manual steering worm gear and hydrostatic orbitrol under the fuel tank. There is room to do all this and you have three more inches of frame length than I do. I won't know the results for a few weeks. I have a lot to do yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 2:19pm
Didn't thing of that motor! Thanks and Ill check back with you on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 2:39pm
Don't get too excited about that combine engine just yet. Most Gleaner combine engines don't have a provision for mounting a hydraulic pump on them. I've had to pull off the front cover, camshaft and front engine plate and swap those parts for tractor parts and then spend $$$$$ for a 190XT hydraulic pump and drive. It will be all really neat when completed, but also a lot of work.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 3:08pm
Store the diesel engine (for possible future use) and drop a gas 262 in it.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 9:12pm
you surely don't use it as a main tractor doing lots of hrs? I'd go with the gas 262....you're biggest challenge will be finding a tractor governor
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 10:14pm
When I had the fuel business I had several customers with 262 gas combine motors in D19's. Must be a easy swap.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2019 at 6:07am
In situations like yours I've found it to be more cost effective to buy another tractor like the one I have and use my original one for parts or combine the two.
