Gleaner F2
Josh N View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh N Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F2
    Posted: 05 Oct 2019 at 9:24pm
What heads fit on the gleaner F2 ? Will a 313 or 315 fit or just models before them? And does anyone have a flex head to fit my f2 in or close to pa
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2019 at 9:43pm
JD 216- 915 with a little work
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 6:05am
Mack, in your opinion, what was the most "challenging" issue that came up during the modifications to make the 2 units work? How did you get the reel to run on the green head, aren't they run with a pump ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 6:30am
Mounted a hydraulic pump above right drive shaft. Used a flow control valve with control cable to cab.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 8:56am
Josh, is your F-2 combine equipped with auto-header height control ??? That feature was NOT necessarily standard equipment.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 9:06am
Our local Allis dealer used to have a kit available to add auto header height control to older F and F2s.  In which case the 313 head could be used to work with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh N Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 9:53am
Yes dr. It has the valve on right side of cab.   Just bought the machine. Didn’t get it home yet. Has a 13 ft ridged head. Like to find a flex head and get the auto control working.   Kinda new to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 8:27pm
Best to get a head with electric header control, and put electric valve on combine. You will hate the oil heating hydraulic control even with helper springs.            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh N Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 9:07pm
Mack which model gleaner head had the electric header control?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 9:22pm
300 series came with the electric height control system, but that doesn't mean there isn't an older 200 series head that has been converted to electric.  You have to add-on and electric control valve system to the combine if you choose to go that way with the header.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 7:44am
F3 and up. There was a kit to put electric valve on older combines.       MAck
