ATF vs Hydraulic Fluid in D17 s4? |
Post Reply ![]() |
JBergie ![]() Silver Level ![]() ![]() Joined: 14 Oct 2018 Location: Minnesota Points: 54 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Sep 2019 at 8:26pm |
I'm sure this is a question that's been covered before but I couldn't find it off the bat.
My D17 s4 has a pto leak and before I fix it, I need to use it! So I thought I'd top off the fluid, but am not 100% sure if best to use ATF or hydraulic. Pros and cons to each. (Isn't the reservoir shared?) Thoughts? |
D17 Series IV
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Universal hydraulic. MACK
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
ATF is too thin. Use hydraulic fluid
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9916 |
Make sure it has the 821 specification.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88098 |
821 spec is nice, but not a requirement for a D series........... any economy UTF is OK.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5030 |
I was under the impression that the D-17 Series IV had basically the same hydraulic system as the 170 and did require the 821 spec oil. Am I wrong? |
You are not wrong WF.
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
Is it leaking out the rear around the PTO? If so, that reservoir is not shared with the hydraulics. The Power director and hydraulics share oil but the trans and rear end is separate. Having said that you should fill both reservoirs with 821 oil.
Mosin9130 ![]() Bronze Level ![]() ![]() Joined: 23 Jul 2012 Location: North Texas Points: 136 |
Thread discussion is perfect as I’m about to change fluids on my D17 IV but I wanted to verify a couple of things. Per the operators manual:
Power director and hydraulics - type A auto trans fluid Transmission and rear gears - SAE 80 transmission fluid Considering the quality of modern day fluids, the appropriate fluid to replace BOTH is universal hydraulic fluid (821 spec)? Edited by Mosin9130 - 29 Sep 2019 at 8:43pm |
'56 WD 45...'63 D15 II...'66 D17 IV
Post Reply ![]() |
