200 tie rod question
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Topic: 200 tie rod question
    Posted: 16 Sep 2019 at 11:44pm
On the tie rod is the nuts suppose to be on the top or bottom that closest to the spindle. Same goes for the one underneath the the tractor. Reason why I'm asking this is I just bought 2 new ones and I'm having one heck of a time getting them to stay I've tighten them as tight as one can go without breaking the bolt and still have a tendency to move alittle. I have them set in those notches on the tie rod.
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 1:55am
Every one I've seen, the nuts are on the bottom on both ends. They should be castle nuts with cotter pins through them so that they don't come apart once installed. If you have tightened the nuts to the end of the threads and still have some up/down play, then there is an issue with the tie rods (aftermarket??) either not having threaded the bolt far enough or made the bolt too long to begin with. You should be ok to add a washer before the nut as long as you can still get the cotter pin installed correctly through the bolt AND castle nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 7:44am
Find old tie rods and take clamps off them and install on new ones.          MACK
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 8:16am
Couple of random thoughts on this. I have had trouble getting the tow-in to stay put on Dad's 185 and my D-17. Both have new aftermarket tie-rods. Got so fed up with the 185 I resorted to welding them. First time I had to reset the 17 they got welded too. This works, just real unhandy if you want to change tread spacing.
I have kept the original clamps off of all the ones I have replaced and intend to double clamp in the future. I think the new tubes will need split a little farther to make the double clamp set-up work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 8:19am
I was confused at first. I thought you were talking about the ends. Now, I realize that you were talking about the tie rod length adjustment. I've heard there is an issue with the new clamps on aftermarket tie rods not holding. I hope they fix that by the time I buy a set for the 190XT since the old tie rods don't have clamps anymore because they were welded solid years ago.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 10:11am
On my 190 and 200 still original tie rods spindle end nut on the bottom center under tractor nut on top so you can grease the joints on the end.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 12:00pm
I recently fixed my tie rod on my 190XT and I bought my tie rod from Agco at about twice the price as the aftermarket prices as recommended here on the forum. Everything fit fine and tightened up just fine. I did have to retighten the clamp after my first test. Been good ever since. Agco tie rods have the clamp welded on I believe.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 1:15pm
DanWi is correct    One nut on top and one on bottom
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 2:04pm
Thanks for your replies I bought these tie rods through All state tractor parts. The clamps are welded on the new ones too.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 6:57pm
The factory ends have larger clamps and the rod fits tighter. I had to use the factory clamp from the old end on mine. I think the clamp bolt is on the top. The one with the rod goes on the outside.
I think some of you are thinking about the actual rod ends. They will only fit one way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 8:14pm
Since mine were rusted in place, I replaced the whole unit as its cheaper to buy the whole assembly. Thought I would be smart and put anti seize on the rods so they wouldn’t rust in place so I could change my front end width for plowing. Haha, as soon as I turned the steering wheel the rod moved but not the wheels. Yeah, spent another hour each side removing the anti seize before I got good clamping force. Don’t do that. Used Agco parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 9:26am
AC720MAN, in theory that sounds like a good idea.  Sometimes they aren't.  Appreciate the chuckle.   I did discover that you have to tighten up pretty tight though without anti-seize.  I had to buy both parts because I could not get the old two separated either.
