Please identify this Tractor
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Topic: Please identify this Tractor
    Posted: 12 Sep 2019 at 5:42pm
My first post here; I hope I am in the right place.
I took these photos at a recent show.
I cannot identify this tractor; I sort of think maybe a D17, but I may be miles off.
The rear tires are 14.9-28 (13-28).
I can't even determine whether it is 4- or 6-cylinder.
For comparison, it is flanked by a D19 and a C. (The D19 decal is still present on the other side)
Can anyone enlighten me as to the model and hopefully the year ?
Artfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Artfarm Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 6:24pm
D-17 series 1 gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 6:28pm
1957 D17...  if the grille is original!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 6:48pm
Mystery Solved ! and most appreciated.
I have a few other mystery A-Cs that I will post in the near future.
Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 7:34pm
Here is another unidentified A-C and now I suspect that it also may be a D17.
Notice the industrial (backhoe) tire on the right-rear; I thought all backhoe tires were 24" ; I have never before seen a 28" backhoe tire, so this A-C may be on 24" rubber (or a 24" on the right and 28" on the left.
Is this tractor also a D17 ?  year and model?
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 8:22pm
I believe that one is a D14.
The rear tires should be 14.9 x 26 though.
Edited by frnkeore - 12 Sep 2019 at 8:24pm
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Artfarm Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 8:26pm
D-14 looks to be 26'' combine rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 11:25pm
Thanks so much for the identification.
Here is another that I have not been able to identify:
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 11:45pm
As much as I enjoy seeing them shined up, I enjoy these still working tractors. Lots of longevity helping somebody scratch out a living and I am sure some assistance from the members here to keep them that way.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 11:50pm
That would be a "WC" with non-factory rear spoke rims.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 12:03am
So that would be an early "un-styled" WC.
The tractor just the other side of the "G" , the one with the home-made wooden tool-box, is labeled as a 1942 WC.
The description says that, because of the war, it came with steel wheels/tires and the wheels on it and this WC pictured both appear to be home-made "conversion" wheels with spokes welded into open-center rims.
Thanks for the identification.
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 6:24am
The blue popup tent in the back ground is the eye catcher.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 1:13pm
Here is another that I have been wondering about for some time.
This one has the wheel centers dropped below the axle center.
The crease above the radiator looks as if a flat-bed truck has backed into the tractor.
I may be fooled; but, I can't imagine this small tractor handling big rolls of hay on the loader.
Check out the third-arm.
Although not pictured, there is a hay spike on the rear as well.
What model is this one ?
Edited by BuckSkin - 13 Sep 2019 at 1:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 1:29pm
That would be a “WD-45”.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 2:11pm
Thanks !
After I saw what looks like a hydraulic tank cap on the loader frame, I did a bit of reading on the 445 loader.
From what I can gather from the very limited information that I found, the 445 loader kit has it's own hydraulic pump and system, completely independent of the tractor's hydraulics --- is that correct ?
I have a completely independent Kwik-Way Loader on my 1971-72 Mitsubishi R2500.
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 11:26pm
Wow, that looks like a pretty good bend in that wide front axle from my viewpoint. I hope they have another front axle laying around or they retire her soon before she gives up herself.
