Wd 45 rear section in a wd frame and engine
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Wd 45 rear section in a wd frame and engine
    Posted: 06 Sep 2019 at 10:16pm
Found a wd 45 rear end and transmission online for my wd. I could use it since my transmission is noisy and the 45 combo has a lower first gear
I am wondering if the 45 transmission and rear end will bolt to my frame engine and final drives?
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2019 at 10:49pm
Dan,
 Seems like that should work fine. Good luck with your rebuild.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2019 at 7:55am
The last 20,000 or so WD's were built with that rear section and curved gear shift.
Should be a bolt in
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2019 at 10:05pm
Make sure it don't jump out of gear.        MACK
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2019 at 9:42am
Our '53 WD had the curved shifter stick like the WD-45. The tires were smaller than the '45. I don't know if the wheels were the same. If I remember right the WD's were 12" and the '45 were 13".
Dusty
