200 Cab fan
Rhoadesy_65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rhoadesy_65 Quote  Post ReplyReply Direct Link To This Post Topic: 200 Cab fan
    Posted: 05 Sep 2019 at 8:25am
My 200 has the factory cab without A/C. The blower fan only works in high, makes a terrible noise, and turns on and off intermittently. I would like to get it working again. Any suggestions? I had the shield off the other day and couldnt find any loose wires.
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 9:47am
Working only on high could be the switch. The switch has a resistor for low speed. Off and on would point to the motor drawing too much current and tripping the circuit breaker. Noise could mean a bad motor or a fan problem.
At SN 4001, there were a lot of changes.
Blower motor PN 70257336 prior to 4001, PN 70256769 4001 up. These are 2 wire motors.
Controls were also different.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 11:43am
On ours, the intermittent problem is a loose connector at the base of the cab.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 2:26pm
For starters spray the ends where the shaft goes thru with your favorite oil should help. It does help a little if you can get the fan out to do it, then you can turn it on end and let oil run down the shaft.
