Left hand feed implements. |
Post Reply ![]() |
exSW ![]() Orange Level ![]() Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Aug 2019 at 7:22pm |
What was AC's reasons for building combines,rotobalers and other equipment that had left handed pickups?
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8456 |
Could it be because binders were left-hand cut, so they just kept building things that way?
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8654 |
The left side works better for me with hyd and hand clutch on all crop(WD45). Yes you set crooked in the seat but it wouldn't work in reverse.
Edited by SteveM C/IL - 31 Aug 2019 at 9:12pm |
TimCNY ![]() Orange Level ![]() Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
Because "right side" was already taken?
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
When you sit on the right side of the tractor, like the WC, it's easier to turn to look to the left, than it is to look right.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3093 |
Why didn't they make sickle bar mowers cutter bars be on the left side?
Road frontage. You'd be against traffic. Municipalities used to use sickle bars to mow along the public road ROW.
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
The corn binders I'm familiar with were right hand. |
I guess the geographical difference explains why I've never seen a corn binder in person. I had grain binders in mind.
200Tom1 ![]() Orange Level ![]() ![]() Joined: 03 Jun 2019 Location: Iowa Points: 1232 |
Round balers were on the opposite side because they worked better with the hand clutch. After baling 10's of thousands of bales with a round baler, I bought both an IHC and Deere square baler. I hated using them. Did the AC small square balers have the pickup on the same side as the Deere/IHC?
ranger43 ![]() Bronze Level ![]() Joined: 09 Jun 2019 Location: Huntingburg Points: 155 |
I ask my neighbors this question all the time. They have 5 roto balers and I have 1. They still bale around 4-5000 small rounds a year use to routinely due 15000. In any case it never made any sense to me to have it on the left side. I grew up on WD's and I don't care what people say it would be a hell of a lot easier to look over my right shoulder for the pick-up on the roto. I heard one argument from someone well you its because when you get off the tractor on the left side you are there to work on the feeder. that makes no sense because you get on the WD and 45's from the back of the tractor. Never heard a valid reason.
I doubt the hand clutch had anything to do with it, since the roto baler was in production before there was a hand clutch or a WD. Allis square balers were right side pick up like other makes of the period. Edited by CTuckerNWIL - 02 Sep 2019 at 10:03am |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8726 |
I would guess that back then, right or left hand as a standard hadn't really been established yet, so companies were still dabbling with what worked better. I have no qualms about my roto baler feeder being on the left side. darrel
LionelinKY ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Radcliff,KY Points: 695 |
There might be some validity to that point when you really think about it. When you get off of a tractor on the left, most people would prefer to walk straight back to the implement to address any issues simply because it is easier that way. With right hand feed implements, the operator either has to walk around the front of the tractor or step over the pto shaft at the rear to get to the feeder unit on the right. Even with a "W" series tractor or any other brand of that same vintage for that matter since most were rear mount/dismount back then, you dismount to the left of the pto shaft so the above argument is still valid. As an AC enthusiast, I'd like to think that AC was thinking ahead concerning farmer safety but that would be hard to prove unless some of those engineers are still around.
Post Reply ![]() |
