D17 series 3 power director
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 3 power director
    Posted: 12 Aug 2019 at 5:27pm
I know this has been on here before but my power director lever pops out of high range today when working it hard to load manure. How do you fix it???
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 6:01pm
A few possibilities.
Make sure that the set bolt that holds the lever to the shaft is tight so that the shaft makes the full motion.
There is a stop bolt at the front end of the travel...may need to back it off a little so the power director will lock in.
Shims can be moved inside but that's all I'm going to say about the shims as I have not moved them in a hi-lo type unit. Have done the WD/WD 45 types but they are different.
These are some of the ideas that I remember reading on here. I would think that those with more knowledge will check in with more.   Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 9:26pm
Overcenter plates will need replaced and rollers checked.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 3:00pm
Ok The stop bolt is not there . I moved the plate forward ad it was slotted it seemed to help as it didn’t do it again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 3:05pm
Most likely to jump out when oil is cold and engine is wide open throttle.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 3:17pm
Power director stop bolt on my D 15 is also gone . It does seem to work fine . Thanks
