D-15 govenor question
Richmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Topic: D-15 govenor question
    Posted: 11 Aug 2019 at 3:19pm
Would slightly oval pin holes in the govenor weights  cause  the  govenor to not function properly. It goes from idle to 900 rpm  by just moving the throttle lever very very little.
It is difficult to hold a certain rpm .
All adjustments were made according to the service manual  .  Throttle rod, gov. rod  etc
rich:
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 5:28pm
If the weights are showing signs of ware I would definitely replace them. It is not a good day when one of the weights breaks.
I am not sure if it is the source of your problem but I would suspect it is part of the issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 5:47pm
Going from an idle speed of 400 RPM to 900 RPM is probably related to the surge spring that a D-15 has and may be considered pretty normal. This spring adjustment is separate from the link rod adjustment. Poor governor speed control is usually related to link rod adjustment being too short or dry/rubbing/binding linkage to the carburetor. Worn weights eventually break, but probably aren't what's causing your complaint. Loosen up the surge spring a full turn and see how it reacts.
Edited by DrAllis - 11 Aug 2019 at 5:48pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 10:54pm
The other issue may be the centrifugal advance in your distributor.  Make sure the distributor advance mechanism is clean and properly lubricated, and that there's no slop in the weights, and the springs are intact and serviceable condition.  Poor advance operation will cause the idle RPM to vary with no apparent rhyme or reason.
A worn point cam or sloppy distributor shaft bushing can do it, too.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 1:28pm
Rich , on my D 15 I found a broken spring under the gas tank that hooks to the throttle . Replaced mine but it didn't seem to make much difference . It's #70227736 , I think . Cost me $43 . Thanks
This page was generated in 0.227 seconds.
