Wheel weights |
Post Reply ![]() |
Travis2766 ![]() Silver Level ![]() ![]() Joined: 26 Aug 2015 Location: Amherst, Wi Points: 436 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Aug 2019 at 3:26pm |
Picked up a set of F&H wheel weights at an auction today hoping they will fit my series IV D17, they look like they should. I got 4 weights #161’s and #162’s. Anyone know for sure if these will fit? It looks like they will be very close to the nuts for the power adjust rims. Also anyone know how they bolt on? Obviously they bolt thru the holes in the rims but does one weight go on and then the other bolts through everything or does one go on and the other weight bolts to the first weight?
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2075 |
Not sure if they will fit the D-17, but the weights are for the WC.
Thanks & God Bless
Dennis |
Pete from IL ![]() Silver Level ![]() Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
I just put a set on my D17 series 3. It is not just a bolt on job. You need to make cut outs on the outside of the weights for the bolts for the power adjust rims. I marked mine and made the cutouts with a hole saw. Not really a small job. If you would like to see a picture You can pm your phone number and I can text you some pictures. Pete
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4114 |
I put a set of 4 on the 185, had to 'index' the lug bolts so the 161
would clear. The larger diameter 162 goes on the outside. I like to mount weights with 3/4" all thread. One nut on each side of the wheel center and just slide them on. I'll see if I
can get a pic posted. You can kind of see it here, best pics I have on the computer at the moment.
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Not sure if WD wheel center is same but I have 162 weights on mine and they bolt right up without covering the rim clamp bolts. The smaller 161s are the inside weights used with F&H spoke wheels to fit inside the rim, but could be used with a D17 I suppose.
Edited by Bill_MN - 11 Aug 2019 at 2:04pm |
Post Reply ![]() |
