8070 Hard starting
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Topic: 8070 Hard starting
    Posted: 07 Aug 2019 at 3:38pm
Hi Guys, my 8070 looses prime after sitting for a day.  Probably closer to losing prime after sitting about 5 hrs and seems like it is getting worse.  Use to be about 3 days of sitting before you had to crank it alot.  There is no smoke coming out of the pipe for probably 7-8 secs and then runs like it is short on diesel for the 20-30 secs.  It has been this way for about 10 years.  Last summer, I overhauled the motor, injector pump rebuild at Beemer Diesel (very reputable), checked injectors and good.  All seals on the lines have been replaced during the overhaul. No leaks. Filters changed yearly which is about 50 hrs max. New batteries and cranks fast or like it should.  All this had zero difference on it and maybe even got worse.  It doesn't matter is the tank is 3/4 full or nearly empty. Once started, runs great and power as advertised. With cooler weather coming, it will crank longer to start. I have a holley electric fuel pump on a parted out N5 that I was going to install on the hose from the bottom of the tank. Maybe that will show a leak on the suction side??  Will I hurt anything installing that pump on it pemanently.  I think it is a 5 gpm.   What am I missing? Tractor has about 5500 hrs on it and I've had this tractor since nearly new.  Thanks Greg
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 9:21pm
Well it is about 25 dollars to replace the hose from tank to filter to filter if i remember it is half inch fuel hose and use new clamps
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 9:26pm
Debra in check valves on primer. Check vent on fuel tanks.      MACK
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 7:51am
Mine does the same, except when its full it starts, about 3/4 full it starts fine. I have replaced every fuel hose on it and checked the hose on the return line inside the tank. I will try the primer and the tank vents next. Thanks for the info.
Randy
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 8:06am
Do you guys have the updated fuel return line that goes into the tank? Had the same problem with our 8030. Fixed it right up.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 8:34am
What is the difference with the updated fuel return line?
Should every 8000 series have it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 8:40am
The first 8000 series just had the return into the top of the tank, the later ones and updated tractors have it go into the top of the tank with a tube that goes to the bottom of the tank. That way it doesn't drain the return line along with the head of the pump. Yes all should have the update done. Ill get you guys a scan of the factory update sheet.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 9:54am
I bet I've got two 80xx tractors that need this update. Never new anything about it but now I think I'll take a look at the return line in the tank.
Thanks
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 10:21am
Figured it was the return draining away somehow.  Priming pump is new with the injector pump overhaul as it is on the injector pump. Breather vent is good also. Curious too on the return line fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 11:21am
Here ya guys go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 12:55pm
sounds like my 84 model has the "correction"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 1:15pm
Thanks for the info!
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 5:04pm
Mine has the hose in it. Going to check the pump for debris in it.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 5:16pm
A lot of times that plastic tube falls off and is laying in the bottom of the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 5:54pm
Inpumped, chime in on this!
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 8:28pm
Our 7000 tends to do this as well but I assuming it has to do with the small fuel leak im seeing on the injection pump
If fishing is a sport your looking at an athlete
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 8:33am
Looks like it's being handled plus I learned something. I as a pump re-builder, hate on engine plumbing issues! They are almost as hard to diagnose as electrical gremlins!
