D 15 lift/lower lever
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 lift/lower lever
    Posted: 03 Aug 2019 at 6:35pm
Mine won't stay up . The "nub" that fits in the window is worn , I guess . Anyone fixed this before.? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2019 at 6:39pm
Troy, my #1 D-14, has a blob of braze that 'replaced' the original pin. You only need it if you have to keep the pump running, not for regular lifting.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2019 at 7:57pm
It's about 5 miles on the paved road to the "farm" Don't want my harrow to drift down on the asphalt . I might could do a blob ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 5:43am
I put 'carrying chains' on my D-14s. Just a 4' section of 5/16" chain with a grab hook on one end. I loop it through the horizontal bar of the seat support so it's always onboard. I use it to keep the rototiller or plow up during transport.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 7:02am
Thanks Jay . That's another option .
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 7:47am
The carry chain option eliminates the need for the pump to continuously run when transporting heavy implements. It also minimizes the strain on the hydraulic lines/fittings. I had a chain hook welded to the top link bracket to hook the carry chain into.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 7:59am
The lift/lower lever has a "hold" position at the half-way point. There is no need to leave the lever locked in the up/pumping position and you shouldn't.  The operators manual clearly says once the implement is raised to the desired height, place the lift/lower lever in the hold position.If the implement settles in the hold position, there is something wrong with the hold valve, internal hose or packing on the lift arm cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 8:14am
Thanks Dr Allis . Guess I need to take another look at the op manual . What are the 2 windows and the pin for I wonder ? I'm sure my old D 15 has lots of hydraulic issues .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 8:41am
Out in the shop now and I see that the manual says the windows are for lowering and raising . Guess when it's not worn out you don't have to hold the lever up . Thanks
