Space saver spare wheel |
Steve allis dozer
Silver Level Access
Joined: 10 Apr 2011 Location: Australia Points: 232 |
Topic: Space saver spare wheelPosted: 01 Aug 2019 at 7:21am |
I modified a space saver wheel off a honda car it has the same hole pattern as the ca , I just bored the centre hole out a bit and moved the centre of the rim in a bit and re welded it , they are a cheap way of replacing rust rims and the tyres work well
Steve allis dozer
Silver Level Access
Posted: 01 Aug 2019 at 7:23am |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34637 |
Posted: 01 Aug 2019 at 7:51am |
Since you cut the centers loose, could you just cut the center out of your old rim and welded it into the doughnut rim and have a similar look of original rim?
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3200 |
Posted: 01 Aug 2019 at 8:01am |
There is some wheel like that one that will fit with no modification except cut the center just a little,have a D10 with them on it bought it that way.
Steve allis dozer
Silver Level Access
Posted: 01 Aug 2019 at 9:26am |
my centres were damaged and there are not many Allis tractors around here anymore , the wheel weights fit in as well
DougS
Posted: 01 Aug 2019 at 9:29am |
There should be a bunch of those in the junkyards. I can't imagine very many people chasing after a space saver wheel.
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 01 Aug 2019 at 4:26pm |
Just remember to not go over 50 with it.😜
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 01 Aug 2019 at 5:16pm |
Brian S(NY)
Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3383 |
Posted: 01 Aug 2019 at 5:22pm |
I put Two of them on Dads "B". Then I bought tires and rims at the GOTO in indiana a few years ago but he likes these :) maybe someday we will get the correct ones bolted on :)
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55299 |
Posted: 01 Aug 2019 at 5:40pm |
Sure hope the tire was offa the rim, when you welded on it, if not, there may be a big BOOM, in medical bills...
![]() [TUBE]HiLeji8bLOk[/TUBE]
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Posted: 01 Aug 2019 at 6:41pm |
I 'think' full size Chevy wagon rims will bolt right on, maybe 'old' GMC pickups ? 5 x 4.75 pattern ??
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 01 Aug 2019 at 7:01pm |
I have a B here that I put space savers on, no mod what so ever, not sure now, but I think they were GM
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
HD6GTOM
Posted: 01 Aug 2019 at 7:10pm |
Keep an eye on the lug nuts. Those rims should have a metric bolt pattern.
Rog NCWI
Posted: 01 Aug 2019 at 7:37pm |
I just bought new rim blanks and riveted them on the old wheel centers to make it look like the original ones.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90872 |
Posted: 01 Aug 2019 at 8:01pm |
he is from Australia.......... availability and not-common between USA and Australia might be part of the problem.
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 01 Aug 2019 at 8:11pm |
Say,,,!! That right there is a great idea when the originals are not available,,, Good Job, Steve from down under...... I'm gonna look into this as I am gettin a Massey TO20 rebuilt and I just DO NOT, NOT like them big old skinny tires and wheels they come out with,,, Thanks for the idea,,,cause I gots a torch and a mig welder and ain't scairt to use em
john(MI)
Posted: 01 Aug 2019 at 10:17pm |
I put a set of them on a Farmall A. Used the rims that were on there. Never had a problem so I guess they fit the narrower rim. Sure made it better cutting grass.
