cracked B block
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Topic: cracked B block
    Posted: 27 Jul 2019 at 9:36pm
I tore apart my B engine today searching for the reason why I am getting water in the oil.   I was hoping for freeze plugs in the head but they were good.  Took the head off and found a crack between # 1 and #2 cylinders.  So my question has any one successfully repaired a  cracked block at this location?
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2019 at 9:44pm
Cracks  at the top of the block have no ill effect. Oil and water are sealed at head gasket. Cracks in the bottom web between cylinders are a different story.
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2019 at 9:47pm
I have not taken pan off to look at bottom ,  but it has crack at top and it is mixing water and oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2019 at 10:22pm
The best way to find how water gets in the oil, is BEFORE you take the head off. You remove the oil pan and the rocker cover and pressurize the radiator to 7 psi.
 With the head off, about all you can do is pull the sleeves to see if there is a crack down where the o-ring seals, or a sheared o-ring.
 Also, the only way to tell if the core plugs are good, is to pressurize the coolant system and look at them, or to remove them and replace them. You cant tell a thing by looking at them.
Edited by CTuckerNWIL - 27 Jul 2019 at 10:24pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 5:48am
Just because the "core plugs" (Dick L would be proud that I didn't call them frost plugs!) look good, they still may be leaking. For the couple dollars each they cost, it's pretty inexpensive to replace them. I'm betting that they will look not look so good when you get them out.
As others have said, cracks between the cylinders are very common and are sealed up by the head gasket. The most common coolant in the oil is caused by leaking core plugs n the head, head gasket, crack in the head, holes eaten through the sleeves or O rings on the sleeves leaking.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 7:48am
The only thing I have to add about the cracks between the cylinders that the head gasket seals is, consider the crack you see around the outside of the sleeve and wonder why it does not leak.
If you find small amounts of waster laying in and around the core plugs on top of the head on a running tractor the core plugs will be the culprit.
I put pictures on a few days back of a head I could not see where it was leaking. I knew it was the only way the water could get there so I took a torch to it and found it. We always have had people that wanted to find the source some other place because of the fear of installing new plugs so I took a picture and posted it. This picture was taken in 2007.
Edited by Dick L - 28 Jul 2019 at 7:49am
ryanschott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 8:24am
I’ve tore apart a lot of b or c motors like yours and I have not “I think “ found one that is not cracked so a little crack there won’t hurt anything between the tops of the cylinders
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 9:13am
thanks for all your input,  I will change core plugs and put it back together Hope for the best.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 9:49am
Welding an iron casting is difficult, trying to weld a crack usually adds more cracks near the weld. There is a company at Nevada Iowa that is successful at welding cast iron engine blocks. They heat the whole block almost to welding temperature and then weld the crack and cool the block gently to prevent more cracks. They also repair cracked heads. Their name is Midwest Cylinder Head, 1700 W F Ave, Nevada 515-382-2791.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 1:37pm
For everyone in the future looking for coolant leaks.....remove the pan and valve cover and pressurize the cooling system. Give it time and look for leaks before you tear anything apart. If you have a leak,it show up under pressure and pinpoint where the problem is.Otherwise you are shooting in the dark hoping you addressed the problem and may well miss it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 6:17pm
Keep checking for leaks, over a period of time, let the tractor sit, a while, and loosen the oil drain plug, coolant will be in the bottom of the pan, and will wick through the threads of the plug, before oil will drip out.  For small leaks, try Blue Devil block sealer.  follow the directions on the label.  It contains water glass(sodium silicate), which forms a shell against the leaky surface...Wink
Watch at about 4:30 of this video, automotive uses, explained...
[TUBE]IXQM8nheRv0[/TUBE]
Edited by DiyDave - 28 Jul 2019 at 6:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 6:49pm
very informative video Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2019 at 4:33pm
Drained the oil pan and got at least a gallon of pure water before milk chocolate  oil came out.   found a block close to home for $50,  bought it and will rebuild the engine.  Then I know it is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2019 at 4:39pm
...IF the block you bought is good.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2019 at 9:07pm
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2019 at 10:39pm
Well  WF  I asked and was told no cracks.  When I get it home and if  I see a crack it will go back to original owner.  I will believe the young man is trust worthy enough to not lie to me at this point in time.
