200 power director |
mike-mn
Topic: 200 power directorPosted: 27 Jul 2019 at 7:53am |
My power director slips in high. Is the adjustment for that the two nuts on the down rod from the cab? I think I have read that the rod for the control valve is not going far enough. Thanks again.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2490 |
Posted: 27 Jul 2019 at 8:30am |
If your tractor has the notched gate shifter,try holding the lever further ahead and see if that helps. The gate can be built up and the threaded rod can be repositioned in the lever for better stroke of the spool if it has that style of shifter. Also the bushing in the transmission housing can be worn and let the lever assembly be sloppy.
Edited by Lynn Marshall - 27 Jul 2019 at 8:34am |
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 27 Jul 2019 at 6:08pm |
If it is a gated shifter, it will have springs on the actuating rod. Make sure the are compressed some at full stork of the lever. There also should be another hole in the bell crank that give more travel.
Also check the bushings on the bell crank.
DougG
Posted: 27 Jul 2019 at 6:17pm |
The linkage on those are so finicky,, look for wear points and Make sure its getting the correct hydraulic pressure to the clutch packs ,, a steady pressure, as fluctuating pressure means O rings out and oil sliding thru,,also 200 Powerdirector are known to break easy,,
