AC disc repair |
onestout
Topic: AC disc repairPosted: 20 Jul 2019 at 5:44pm |
New to the forum, first time post. I have an older 14' wide disc (not sure which model it is, no tag or marking) and I lost 1 gang. bearing holder and shaft broke. I like my older AC stuff but I'm having a hard time finding parts for this. Is it worth it to try and salvage or would I be better parting it out and find a different disc (tough to answer that)? The shaft is a 1" hex. It's too bad, it sure worked good when it was working. I saw the pinned thread on the bearing rebuild, does that work for the Hex shaft as well? Thanks
rtwfarm
Joined: 26 Feb 2012 Location: nebraska Points: 1349 |
Posted: 20 Jul 2019 at 5:54pm |
I have a couple of parts disks. Give me a call Ryan 402-469-1738
orangereborn
Posted: 21 Jul 2019 at 9:23pm |
Welcome to the forum...I am at Somerset/New Richmond...Dale
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3132 |
Posted: 22 Jul 2019 at 6:52am |
The round and hex balpak bearings are the same. The bearing has an inner sleeve that pressing out. It can be either a round or hex sleeve.
TimNearFortWorth
Posted: 22 Jul 2019 at 10:07am |
If the rest of the unit is solid, frame, axle mounts, hitch and not all cobbled up with old welds, you can look at replacement gang assemblies.
Numerous supply companies can supply the entire gang with hanger brackets that can be welded directly to your frames. Pick common carriers that are easy to reach for lubing, blade type, size/thickness and hangers, just watch you do not oversize what it originally had as too aggressive will not last as some of those older discs had pretty light frames.
onestout
Posted: 22 Jul 2019 at 12:24pm |
Thanks for the responses. I am looking into our options. I am guessing the other bearing and shafts are going to be in the same condition but it was raining so I didn't have a lot of time to look at it. Overall the frame and everything seems to be in pretty good shape. Any help on the model #?
Tenn allis
Joined: 24 Nov 2016 Location: Tennessee Points: 152 |
Posted: 22 Jul 2019 at 1:02pm |
Looks like a 2300 old style hangers and bearings Frame looks to be in good shape
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 23 Jul 2019 at 6:46am |
Is it a 2200 disk? Dad has a 2200 in the weeds that I intend to restore some day but they are prone to breaking the hex spindle axle.
Wink I am a Russian Bot |
orangereborn
Posted: 24 Jul 2019 at 12:24am |
onestout
Posted: 24 Jul 2019 at 10:20pm |
thanks for all the replies. I will figure out what I need and get in touch with you. Great site and good to see the old stuff kept up. |
