Dumb Question About Single Front Wheel
AC7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7040 Quote  Post ReplyReply Direct Link To This Post Topic: Dumb Question About Single Front Wheel
    Posted: 10 Jul 2019 at 10:09pm
So called local tire shop to see about replacing the front tire on my wd45 single front wheel setup. While discussing tire options, we both wondered how best to remove the old tire from the rim? Said he's been there for 25 years and never had to change one. Is there anything special to removing the tire? I noticed that there appears to be bolts around the rim on both sides so I'm kinda thinking the rim is 2 pieces and you remove the bolts to split the rim and remove the tire? But I'm probably why off...
1953-WD45, 1949-G, 1950s Snap-Coupler All-Crop Drill, 1956 Roto-Baler, 1945 All Crop 60, Snap Coupler Subsoiler, Plow, Gleaner F, 505 wagon
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 10:40pm
looks like a retainer plate on each side
Edited by JoeM(GA) - 10 Jul 2019 at 10:44pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 4:55am
I'm not 100% sure about the WD45. My SFW CA is a one piece, cast iron (very heavy) front wheel. On the CA, you take the bolts out of the sides and the whole thing comes off.
Reinstalling is pretty much a two person job. I jacked the tractor front high enough that I could balance the tire and wheel on a floor jack and I moved the tire/wheel into position while my helper (very patient wife) put the bolts in.
The parts book blow up that Joe posted should help you!
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 11:19am
Take it to your local tire shop. Have them break the bead off the rim. Unbolt all bolts. If its like dads wd45, the rim will come apart. Wire brush everything. To put the new tire on, lube the beads and bolt everything back together. I have done several over the years, not too hard.
Edited by 200Tom1 - 11 Jul 2019 at 11:23am
