D19 PD Help Needed |
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1186 |
Topic: D19 PD Help NeededPosted: 29 Jun 2019 at 11:00am |
My power director seems to be loosing fluid around the handle shaft. I removed the handle/lever but find nothing but the casting and shaft. Looks like any seal must be inside? I would appreciate any direction offered.
Bill Deppe/AC Salvag
Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 976 |
Posted: 29 Jun 2019 at 1:45pm |
Believe there should be a groove on each side of the handle shaft for an o-ring
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 29 Jun 2019 at 2:10pm |
Yes...supposed to be an O-ring in there....Rick
Jim.ME
Posted: 29 Jun 2019 at 2:15pm |
See attached pdf. The lower drawing and the lower group of part numbers apply to your question.
D19_power_director_fork_shaft.pdf You can sign in as a guest user and access the parts book at AGCO Parts Books |
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 29 Jun 2019 at 9:53pm |
I was told by an old timer that if you had small hands (or kids or grandkids ) you can remove the snap ring on the left and the handle off you could slid the shaft out the other side enough to expose the oring then replace it then slide back the other way and change the other oring then the little hands can help get the key in place as you slide the shaft back in place Maybe the dr or somebody else can say yes or no about doing this
MACK
Posted: 29 Jun 2019 at 10:02pm |
Remove the handle, remove snap ring on left side. Remove cover on right side. If there is a setscrew on shaft inside, remove it. Slide shaft just far enough to expose snapping and replace it. Move other direction and do the same. MACK
DrAllis
Posted: 29 Jun 2019 at 11:47pm |
D-19 shouldn't have an internal setscrew, just half-moon keys. So, no need to remove right side cover. Place the hand lever fully into LOW range and remove the long handle from the shaft. Gently move the shaft side to side just enough to roll out old Orings and roll in new Orings from an AGCO dealership.
DrAllis
Posted: 02 Jul 2019 at 8:28am |
bump
KenBWisc
Posted: 03 Jul 2019 at 8:46am |
Thanks much for the replies. A very simple process once direction is received! Thanks too to the Dr. for bumping this back to the top. Not certain why my physical or site search came up empty.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 03 Jul 2019 at 10:51am |
I'm sure the AGCO o-rings aren't just plain general use o-rings so I'd get them from AGCO as the DR says
Wink I am a Russian Bot |
