Radiator Recore
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Topic: Radiator Recore
    Posted: 08 Jun 2019 at 10:33pm
My 1962 D-17 (gas) radiator has some leaking tubes.
 How much should it cost to re-core the radiator?
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 11:15pm
I had mine done last winter. I think it was almost $600.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 10:36pm
D-17 gas Radiator part #70229702
I have seen new radiators range from the mid $400 to over $800, on line.
Several of the vendors on here have them for a little under $600.
I may try to patch it myself.  If it does not last then I will seek out a professional radiator shop.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 7:43am
Clay, can you actually get that part number?  I tried to get one for me 7045  a few years ago.  An Agco dealer showed the number, but showed as back ordered.  I ended up doing a recore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 11:41am
If you don't have a reputable shop near enough to re-do, Tony with Tony's Tractors can likely get what you need. He is well versed on inlet/outlet, neck heights and any side bolting for original cowling as he has been in this for quite some time.
Advertises on this site and competitive pricing to boot.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 1:51pm
Take it to a competent honest radiator guy he’ll either fix it or tell you to replace it. When I drop off a rad he calls with a quote to fix it and asks if I can find new cheaper never once have I found new or reman cheaper than him recoring it. Certain point you have to pay to play
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 6:57am
Some of the new ones leave a lot to be desired
Wink
I am a Russian Bot
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 11:31am
Are all the options copper core or are there aluminum cores with composite tanks available?
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2019 at 9:43am
$600 for a new radiator.  I thinkI am going to try to cut out some of the fins and use epoxy to seal the leak.  I have done it on big, heavy equipment, radiators.
Once repaired a hole in a Mercedes diesel radiator. That hole was 1/4" x 1" in the bottom of the tank.
At this point in the game, I think I will spin the luck wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 9:01am
Give it a whirl , should work , ive done a few
