100 Series Oil Pressure Light?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: 100 Series Oil Pressure Light?
    Posted: 07 Jun 2019 at 7:16pm
Was discing last night in some unfavorable conditions (mud) and as the dualled-up XT rear wheels were flinging slop with the disc RAISED, I was reminded of my youth in the same area of the field before it was tiled with a the dualled-up D-17 flinging the same slop 46 years ago!! My question is, why don't the 100 series have an oil pressure gauge? The D 17 at least had a gauge with a needle, it ran on the"M" in NORMAL as I recall, but the 100 series only has the red "idiot" light. If a guy was to install a mechanical gauge, what would be the normal PSI #? Do the 2900 diesels have the same pressure as their 2800 gasser engines?
Edited by FREEDGUY - 07 Jun 2019 at 7:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 7:51pm
Exact reason why I installed a 60 psi gauge.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 8:11pm
I took the traction booster guage out of my 190 and put an oil pressure guage in its place. Got a 60 psi guage from stiener even says Allis Chalmers on it. Used a T at the block so the oil pressure light still works.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 8:13pm
I put a mechanical gauge in the dash and left the red light but I put a Flasher and a buzzer in line with the light and about the time you get one step down the buzzer tells you you left a key on dumb dumb
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 8:20pm
I put a tee in mine as well. Idiot light and gauge both work.
