1939 b motor just seized
archangel_cpj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Topic: 1939 b motor just seized
    Posted: 29 May 2019 at 9:27pm
Mowing the grass with the 39 b positive oil pressure and not running hot at all... The motor seized up out of nowhere... Im suspecting a spun main??? Since my shop went with the divorce is it possible to do an im frame rebuild??? Or should I sell it and buy a lawn mower???
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 9:58pm
An in-frame rebuild is possible. Of course, until you know exactly what went wrong, you won’t know what needs to be fixed. Assuming a spun bearing, that can be done in frame, but it’s, comparatively, a pain. I guess if you had good compression, you could just get new bearings, see if the crank needs machining and go that way.
Now stay tuned for a parade of people who will say that a full rebuild on a stand with a rebuilt head, new liners and pistons is the only way to go....but I assure you that our grandfathers who farmed with these things would probably have just replaced the bearings and got years of use.
1951 B
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 9:58pm
Not if the crankshaft is damaged! If it was not knocking you might check for other places that might cause it to lock up. Like bolts in the torque tube turning in on the flywheel, something in the clutch or the power take off gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 10:30pm
It wasnt knocking before.... The PTO still spins manually I put it in 3rd gear and rocked its stuck solid I push in clutch tractor rolls...
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 10:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 10:51pm
If there is no bolts in the sides then pull the pan and see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 11:04pm
Once i can get it indoors ill pull pan...
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2019 at 9:17am
Long shot for your situation but I have had starters lock against the ring gear and lock an engine right up until I take the starter off or out. Any chance you hit the starter and it bound up or the solenoid when weird and locked it up? Long shot but I try to look for the easy stuff before doing an in-frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2019 at 9:35am
39 B?  Probably no starter.  Certainly no solenoid.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2019 at 10:58am
Good thought! I assumed it locked up while mowing. It actually does not say that in his open post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2019 at 12:29pm
It has a starter ill try it
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2019 at 1:47pm
I'm kinda simple so forgive me for asking but ,just to be clear,did it "seize" while running or it was fine until you went to start it again? Clarify.
