D17 serial number question
Hawsie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hawsie Quote  Post ReplyReply Direct Link To This Post Topic: D17 serial number question
    Posted: 20 May 2019 at 12:27am
.  I have been somewhat mystified when it comes to trying to determine what year or even what series  D17 tractor I have. I have seen the break down by serial number  for year and series and that certainly is straight forward enough, and unless I am reading the numbers wrong it appears that my serial number is 1212 which would be the very first year and of course series 1. But there are many unexplained differences between what my tractor has and what that early of a serial number is supposed to have. I have determined much of this by studying the parts book which shows what parts came with with certain serial number breakdowns. I know that after so many years parts could be swapped back and forth but its more then one part or one area. First there is the very old looking decals that say series IV. Then my air cleaner is the horizontal newer type, so is my dash and my power steering lines.There are others. The main questions I had was firstly on D17 models does the ID number start with D17 then the serial number? I assumed this was the case as mine shows D171212 meaning D17 serial number 1212. The other questions was in regards to the snap hitch. Was this available on all 4 series or was is discontinued on series IV? Mine has it. uploads/9178/IMG_0009_2019-05-20_00-20-48.jpeg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hawsie Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 12:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 7:02am
Can you put up some pictures of the rest of tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 7:19am
Not a series 4. White plastic steering wheel makes it 1960 to 1963. Dry type air filter means series 3 but could have been added by someone. Serial number says 1957 but doesn't say "D" for diesel on the end of it.  Looks like a thrown together tractor of many different parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 7:20am
Hawsie,
Sounds like a early one to me. I never trust the decals. And parts of tractors can be switched with others too. BTDT! Sounds like you may have all of that too. My 17 (series I) has later series II decals and had a cream grill. Both not correct for that tractor.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 7:58am
The snap coupler was available on all 4 series and on through the 100 series as well..
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 8:22am
No snap coupler hitches on a 170 or 180. Only the earlier 190/190XT's had that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 8:55am
Oops.  Thanks for the correction, Dr.
AaronSEIA
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 9:17am
Headlights on the fenders are for Series III or IV models only.  I agree with Dr. Allis - you have a frankenstein tractor.  Sometimes I wish these things could talk to describe what kind of life they have had.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 7:59pm
Sounds like a Johnny Cash special. Post a picture of the whole tractor. Front axle ???
