Cooler hoses
joelsplace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Topic: Cooler hoses
    Posted: 17 May 2019 at 4:11pm
Another newbie question.  My radiator was stolen so of course they cut the lines.  Confusing thing is there are 3 lines that seem to be cooler lines to the radiator.  I see 2 in the parts book.  What is the 3rd and where does it go?
There is one short line from the filter on the left but there are 2 on the right.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 5:04pm
Assuming you are still talking about the 70xx series, there were two hoses that went into one side, using a pipe "tee" at the cooler port.  then only one line on the other side.  Some tractors had an auxiliary trans oil cooler, your probably does it is has the three lines, but upon hazy reflection, and the parts books, I do seem to remember both sides would have two lines in the bottom of the radiator if you have the aux cooler.  If they stole the radiator, maybe they got the aux cooler also, and the 4th line went with it.
Take a look at agco parts books . com for your tractor, and you will see a pretty good illustration.
Edited by Orange Blood - 17 May 2019 at 5:13pm
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 5:14pm
Same 7040.   I guess that would help.
I looked there before I posted here but I only see one line on each side.
I just looked again and I think I see the issue.  There appears to be a cooler in the radiator and a separate cooled they call the power steering cooler.  that means I'm not seeing a 4th line?  Maybe between the power steering cooler and the T you mentioned?
Thanks!
1975 7040 w/Power Director
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 5:25pm
Thanks!
The power steering lines and the transmission lines should not interconnect, those are two different hydraulic circuits.  Mixing those could cause all sorts of problems.
I thought you were talking about a 7040, which shouldn't have the aux trans cooler, but it could easily be added, look at a 7060 for example, and you will see what I am talking about.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 5:31pm
It has a transmission cooler in the radiator and an external cooler for the power steering.  I found the 4th line it is up high over the engine.
I have ordered a service manual and operator's manual.
Edited by joelsplace - 17 May 2019 at 5:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 6:00pm
Where does the power steering get it's fluid?
