Switching to 12 volt
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Topic: Switching to 12 volt
    Posted: 09 May 2019 at 4:10pm
Switching my 45 to 12 volt. My question is, the hot wire running to the alternater (used to be on the cutout) is hot all the time, do I need to hook it up to the ignition switch so it shuts off?
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 5:14pm
You need a diode in between the alternator and the ignition switch, or you won't be able to shut the tractor off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 5:33pm
Thanks CT. But do I have to stop the 12 V going to the alternator when the tractor is not running?
So if I put a diode at the alternator I would not wire it to the switch.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 6:18pm
If you are running a one wire alternator, No.  don't even need a diode in line...
 If you are running a two wire alternator, then you still don't need anything from the charging post on the alternator, to the ammeter, but you do have to put a diode in the exciter wire or it will back feed to the distributor.
 Question is, what alternator are you putting on?
 Now, If you have the old push/pull position light switch, you can wire that to run front lights and all the way out be front and rear lights. or front lights and rear light and all the way out it would turn on extra lights. Thats what I did... I set my switch so it would be off all the way in, first position be front and rear lights with a switch on the rear work light and all the way out, it fired up the Firecracker halogens lights on the hood too. Boy did that tractor have lights.  Sadly at the moment, I don't remember how I changed it to do that but it would not take long to open the box and take a pic.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 6:25pm
You do not have to stop power going to the output terminal of the alternator. Depending on the alternator you use (one wire or three wire), you may need a diode or idiot light to prevent feedback from the excitation terminal.
Go to Steve's site (B&B Custom Circuits), he has info on the differences in the types there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 6:39pm
It is a one wire alternator.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 5:03am
With a one wire you simply hook the alternator to the ammeter where the generator wire used to go. Tie off the F wire that used to run to the generator. Yes, the battery will always be putting voltage to the alternator, but the alternator's diodes should be blocking any current when the alternator isn't turning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 5:33am
re:
yeah..until enough mud and gorf and dampness gets in there, then that crud slowly drains the battery....BTDT, found out it's a GOOD idea to clean your JEEP after going 'offroad'...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 6:57am
Use a three wire set up. Its much better. As Jim in ME mentioned, visit my website. There's lot's of information on 12V conversions there to guide you to doing it right and most of all SAFE. If you have any questions, just give me a call. I'll be glad to help you out with anything. I also offer complete 12V conversion kits if interested...
Website- bb-customcircuits.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 7:03am
I have done several of these and have been happy with the conversions to 12 volt. Its a custom electrical system. I do have a electrical diagram somewhere that I use on these WD series tractors. I believe Steve in NJ helped me set it up.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 7:08am
As in Steve's website, be careful about running a 12 volt conversion through the stock ammeter.
You have a lot more charging potential with a 12 volt alternator verses a 6 volt generator and could easily overload the ammeter. I changed to a voltmeter and I'm happy with that.
Edited by WF owner - 10 May 2019 at 7:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 7:44am
^^ Yes. A 60-0-60 ammeter is preferred, but with such a wide range it's hard to tell just how much the battery is charging or discharging, especially when the value is only a few amps. My preference would be a voltmeter, but know that you want to be looking at about 14 volts or slightly more, not a mere 12.5 volts when the engine is running. Also, integrate the voltmeter with your key switch. You only want the meter in the circuit when the ignition is switched on.
Edited by DougS - 10 May 2019 at 7:46am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 9:51am
The fundamental limitation with the one wire alternator is that without the charging start excitation wire it has to be spun fast to get it starting charging. Often takes over 2000 RPM at the alternator to get it to start. Once it starts charging it will charge as needed until the engine is stopped. I have a one wire alternator on my gas 4020 and the smallest pulley I could buy for the alternator at a vehicle electric shop, about 2-1/2" diameter with a 7" pulley on the engine crankshaft, takes about 1600 engine RPM to get the alternator charging. After that it charges at engine idle and all other engine speeds.
I have experimented with voltmeter and ammeter and while an voltmeter is easiest to connect it doesn't give proof of the battery being charged, just that there is enough voltage to charge the battery IF the battery is actually connected. The ammeter shows actual battery current and so shows true battery charging and loading.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 11:48am
The inherent problem with a one-wire alternator is that it senses the voltage within itself NOT at the battery. There is a definite volatge drop between the alternator and the battery due to the 'IsquaredR ' losses from the battery cables( BOTH of them...). While this is small when using big, fat NEW cables using old ones,even slightly corroded can not allow the battery to receive a proper charge.
Perhaps most don't see it, but it is a factor that should be dealt with.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 2:42pm
Well I run about 10 one wire alternators on various tractors and most of the negative stuff I
read here and other places about them  is totally false as far as I can see.Start the tractor normally and the alternator starts charging no problem.Let one sit for 2 months it starts right up no problem.The ones I get from DB Electric are 62 Amp far more power than the
generator they replaced.They cost about $55 off ebay,you can spend more money but
you will not get anything that will keep the battery charged up better.
