Question on Seal Change
wessel06 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wessel06 Quote  Post ReplyReply Direct Link To This Post Topic: Question on Seal Change
    Posted: 01 Aug 2010 at 2:38pm
I have a 190XT and the rear axle seals are out and I have the tractor jacked up but i dont know how to get the tire and hub off of the axle... To me it looks like all I should have to do is take the 3 bolts out and beat the tire hub back so the hub piece surrounding the axle isn't squeezed tight on the axle... There are two key locks also and dont know if they need to be removed before or can stay in place. I'm confused and frustrated and I need the tractor back out in the hay fields. Thank you in advance to anyone who can give me pointers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 2:51pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Wade (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 3:14pm
Yep, install the pusher bolts in the proper holes, snug them up tight, and hit on the end of axle with the largest sledge hammer you can find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wessel06 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 9:51pm
thank you for the help... i found bolts that thread in but not long enough so im gonna go the the blacksmith in town and have him use a lathe to take off threads on bolts that are long enough. that should work to make my own. thanks again.
