Deluxe seat....
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Topic: Deluxe seat....
    Posted: 27 Mar 2019 at 10:56am
Just put a new cab kit in my 7000. Cleaned it out good. Painted the posts and touch up spots at corners of cab. Looks nice. I took seat back plastic cover off and sprayed silcone grease on every moving part i could find and it still does not work worth a crap. Has anyone successfully made one of these "Deluxe" seats work well? Mine may as well be fixed in position because it does not absorb bumps. I was going to take it out completley to look it over more thoroughly, but the dang thing weighs 150lb and i guess you have to remove the rear window to get it out??? Gave up on that idea pretty quick.
So what options do I have to get either a new seat or make this one tolerable? Its a shame because the seat has a lot of features and is in excellent condition.
Trying to cut down on operator fatigue. I have AC now which is nice. Now I want to save my back
Edited by Dmpaul89 - 27 Mar 2019 at 11:03am
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 11:15am
i'm curious as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 11:37am
If it is the seat suspension I think it is, new rollers and bearings are in order and maybe some welding on the frame when you get it apart. When they were new, they were just barely OK.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 12:58pm
In my black belly 7060 and 7080 I kept the seats and put a K and M manufacturing mechanical suspensions underneath them. Back in the day I did what Doc pointed out to the one in the 8550, but as suggested, less than sub par results. K and M also has the kit to mount their suspension. Your back will appreciate it! Good Luck, Mike
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 1:18pm
I have the same problem. Looked on K&M's site didn't see the suspension as a stand alone. Only showed complete with seat. My seat is also pretty good and I like it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 2:49pm
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 4:00pm
I've tried the mech suspension from:   a&i products
Price is okay, but nothing special.   If you really want a soft ride, get air.    If its just a 100 hours a year it will work.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 4:05pm
K&M Is 302.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 4:54pm
Originally posted by Alvin M Alvin M wrote:
K&M Is 302.00
I thought i saw 500 for the mechanical base on km website maybe i was wrong, also couldnt find 7000 series only the 8000. Unless i bought a whole seat combo
Edited by Dmpaul89 - 27 Mar 2019 at 4:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 9:38pm
The one from Ag Kits is identical to one in my 7080. You'll need to fabricate some perches to support the front of the seat suspension. Good Luck, Mike
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 12:55am
Originally posted by Dmpaul89 Dmpaul89 wrote:
https://www.agkits.com/allis-chalmers-seat-suspension-htss6083.aspx?recrawl&gclid=EAIaIQobChMIvJ-iq4uj4QIVB7XACh1J9AZ2EAQYASABEgIoTfD_BwE#.XJvTWthOkSw
Has anyone tried these suspensions sold by ag kits? About $270. Half the price of K M.
We'll see.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 6:56am
Best to just call K&M. I bought an air suspension and new seat with swivel and it bolted right in. Everything went in and out the door but this was on a 7050. The stock seat is a little different from the deluxe in the newer models.
Wink
I am a Russian Bot
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 2:07pm
While we're in the cab has anyone used Agparts cab interior kit?
This page was generated in 0.124 seconds.
