Ac Ed 40
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Topic: Ac Ed 40
    Posted: 19 Mar 2019 at 12:42pm
Guys any idea where to get the part no or size for AC ED 40 steering box bearings.
Thanks
Edited by everett048 - 19 Mar 2019 at 12:42pm
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 1:06pm
Is there not a number on the bearing itself or could you not take the bearing out and take them to your bearing suppliers so they can match them up
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 5:27pm
You likely have the part numbers from the ED40 parts book at AGCOpartsbooks. If not what I found were 70715042 cup and 70715043 bearing and cage; no luck crossing them to something else as yet however. I wonder if AGCO might have them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 9:58pm
Did about a half hour looking Mark and I can't find anything that matches Jim's numbers.
Sorry....
jollymon68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 10:05pm
Good luck with finding some parts. I would try to match the bearings themselves. You will have better luck in the UK then I am having in the US. I'm still on the look out for a tachometer/hour meter, mine is just a shell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 2:59am
Guys only problem is not enough left to get numbers from all in bits in steering box.
Edited by everett048 - 21 Mar 2019 at 2:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 8:22am
Get yourself a cheap dial caliper, and measure the bore, the depth, and the shaft  OD.
 That is all you really need to find replacement bearings if you have a  good supply house close by.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 10:55am
Maybe worth a check with Sandy Lake to see if they might have any ideas. They have an add in the store here, email and phone contact info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 11:40am
This is not for me just trying to help some one out,They was a piece of junk years ago nothing has changed.
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 3:39am
Hi
I have parts for Gear Box of ED40.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2019 at 2:00pm
John do you have any other parts available?
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2019 at 2:35pm
Hi,
No i have only the gearbox now
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 8:00pm
Thanks...
