7040 steering cylinder
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: 7040 steering cylinder
    Posted: 18 Mar 2019 at 4:37pm
How big of a deal is it to re seal the power steering cylinder from a 7040? Mine seems to have sprung a small leak from one of the seals. Is this something I should do myself or send it in for repair? Thanks in advance.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 6:41pm
Easy job
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 7:51pm
Please explain the easy part,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 7:58pm
No service manual? Shame on you. It's easy.Same as my 8070. Forgot how but it was simple.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 11:26pm
Did my 7060 last year. My service manual is missing the section for cylinder repair. I'd post pics but am having trouble doing so tonight.
There are two snap rings. One external, one internal. I disconnected the hoses then removed the external snap ring. Push in the glandhead(?) to expose the internal snap ring and remove. Use care not to scratch the cylinder bore. Pull the rod assy. out (watch that end, I gouged my leg when I pulled it out) and remove both glandheads from the rod. There are O-rings and seals on inner and outer diameters of the glandheads. I checked the rod and bore for nicks and scratches and made sure the were smooth. After the seals are installed, I lubricated the bore and seals liberally with hydraulic fluid and carefully inserted the assembly installing snap rings in reverse order. Sorry I couldn't get the pics loaded but it should make sense when you see it. HTH.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 9:41am
I thought for sure I had some pictures of the last one I did, can't find em.
I just take loose the piston/rod side of the cylinder, leave the other end attached, leave hoses on.  Take outer retaining ring off, tap in that collar to expose a snap ring inside on the housing.  Pull out the piston/rod assembly.  There is a large nut on the end (new nut came with the AGCO kit).  Be careful on the piston seal, it has to stretch to get it over the piston then you have to compress it to get it in the housing.  I used a large O ring over the top of it with a hose clamp to compress it.  If you just used the hose clamp on it it would probably damage the seal. I set it in there and remove the clamp just before I slide it in.  All of them have worked great that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 9:47am
I sorry I looks like I just repeated the previous post, whoops.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 3:34pm
Thanks, good info here guys. I should hang my head in shame for not having a service manual, I know. Have one for all my other tractors, but not this one. Is AGCO the best source for the rebuild kit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 5:46pm
I would recommend AGCO.  I think the last set I put in was around $70 to 80.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 5:51pm
When you go to stretch the seal over the piston, get a half cup of vegetable oil from the kitchen, Heat it up in the microwave till is too warm to hold you finger in it, then soak the seal for a bit. After getting it on the piston, let it cool and it will shrink some, making assembly easier.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 9:14pm
A buddy of mine told me to use warm water instead of the vegetable oil and it worked just as well
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 4:20pm
Ok ordered the parts today from AGCO $72.10. Can the inner seal be installed without the tool that collapses it or do I need to buy the tool?
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 5:38pm
Did mine without the tool. Bend in a C shape. Not easy
