5015 parts: glow plug, hydraulic pump gaskets
acress View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acress Quote  Post ReplyReply Direct Link To This Post Topic: 5015 parts: glow plug, hydraulic pump gaskets
    Posted: 08 Mar 2019 at 8:32am
I have an AC 5015 4WD Diesel that needs a new glow plug and needs new gasket/seals in the hydraulic pump.
I'm having trouble finding a similar glow plug.  Any recommendations on a substitute?
About the gaskets, they are out of stock, so any thoughts on using a gasket maker product from a tube?
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 8:52am
will this help
Hinomoto was a tractor manufacturer in Japan. They manufactured under their own brand, Hinomoto, as well as for other international companies, including Massey Ferguson, Deutz-Allis, Simplicity and Allis-Chalmers. The company was formerly called Toyosha. Engines were manufactured under the Toyosha brand.
In 1990, the company became part of Hitachi Tierra, and the Hinomoto name was eventually discontinued in 1997.[1]
The E-series was manufactured from 2001 until 2006. The C-series from 1999until 2007. The N-series from 2002 until 2007, some tractor models are in production till 2013
For further information, see Hitachi Tierra.
Tractor Models built by Hinomoto for other companies
Model Year(s) Produced Horsepower Engine Type Misc Notes Photo
Allis-Chalmers 5015 18 hp (13 kW) Yanmar same as Hinomoto C174
and Simplicity 9518
Allis-Chalmers 5020 21 hp (16 kW) same as Simplicity 9523
Allis-Chalmers 5030 26 hp (19 kW) same as Simplicity 9528
Allis-Chalmers 6140 41 hp (31 kW)
Deutz-Allis 5215 18 hp (13 kW) Toyosha same as Hinomoto C174
Deutz-Allis 5220 21 hp (16 kW) Toyosha same as Hinomoto E2304
Deutz-Allis 5220 HST 21 hp (16 kW) Toyosha same as Hinomoto E2304
Deutz-Allis 5230 31 hp (23 kW) Toyosha
Massey Ferguson 205 16 hp (12 kW)
Massey Ferguson 205-4 16 hp (12 kW)
Massey Ferguson 210 21 hp (16 kW)
Massey Ferguson 210-4 21 hp (16 kW)
Massey Ferguson 220 26 hp (19 kW)
Massey Ferguson 220-4 26 hp (19 kW)
Massey Ferguson 1010 16 hp (12 kW) same as Hinomoto C144
Massey Ferguson 1020 17 hp (13 kW) same as Hinomoto C174
Massey Ferguson 1030 23 hp (17 kW)
Massey Ferguson 1040 27 hp (20 kW)
Massey Ferguson 1042 37 hp (28 kW)
Massey Ferguson 1045 1986-1990
Simplicity 9518 18 hp (13 kW) same as Allis-Chalmers 5015
Simplicity 9523 21 hp (16 kW) same as Allis-Chalmers 5020
Simplicity 9528 26 hp (19 kW) same as Allis-Chalmers 5030
References / sources
   B:-)    Dnoym
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 9:48am
Pull the glow plug and look for a number. You should be able to research the manufacturer through that part number. There are glow plug cross reference lists too, just as with spark plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acress Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 10:20am
Thanks Dnoym and DougS.
The plugs at that link don't look like what I have, and it doesn't have a number on it.  And I'm wondering if this really is a glow plug or not.  When I look at the operators manual, the glow plug should be on the top of the engine, but this came from the lower left of the engine near the hydraulic pump.  Here is a picture of it https://drive.google.com/file/d/12NUWj81oQfJFbmUQ7EX46uaAQCDRr4c4/view?usp=sharing
The ceramic top made me think it was a glow plug, but is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 10:51am
That looks like a pressure transducer to me. If the engine uses glow plugs, there should be one for every cylinder. I haven't seen one yet that wasn't at the head either in the head or in the intake manifold.
Edited by DougS - 08 Mar 2019 at 10:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote acress Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 11:05am
A pressure transducer.  Hmmm.  Thanks.  I wouldn't have guessed that.
In looking it up, I see some 'oil pressure switch' parts that look similar.  Much better.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 4:55pm
Yes, an oil pressure sending unit for a warning light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 5:39pm
The glow plugs as stated will be in the head.  They are longer and skinnier, with a ceramic (white) insulator, than the OPSU in the picture.  Tractorbynet.com had a dealer, years ago, when I needed some for a bolens mitizi engine I was working on.  Believe the dealer was down in Roanoke, VA.  You might try taking a GP to your local NAPA dealer, also...Wink
Edited by DiyDave - 08 Mar 2019 at 5:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 6:29pm
look like an  oil pressure sending unit
go to ELECTRICAL & INSTRUMENTS - INSTRUMENTS, GAUGES & WIRING
720994241SWITCH, oil pressure
   B:-)    Dnoym
Edited by Dnoym N. S. Can. - 08 Mar 2019 at 6:36pm
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 1:38am
Go to ebay and see allis 5015 and you will find them
Post Options Post Options   Thanks (0) Thanks(0)   Quote acress Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 10:43am
Found the part and ordered it.  Thanks.
