WD45hydraulic reservoir
Dooner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dooner Quote  Post ReplyReply Direct Link To This Post Topic: WD45hydraulic reservoir
    Posted: 04 Mar 2019 at 8:32pm
I have a dump trailer that I pull with my WD45. The tractor does not have enough oil capacity to dump the trailer all the way. I don't want to revamp the trailer with a smaller ram. I added a extra reservoir on the side of the frame and ran a hose to the case drain. The oil does not want to flow into the factory case. It will, but it takes 15 to 20 min. to transfer a couple of qts. I tried mounting the tank higher and connecting to the filler port, then I had oil running out by the clutch. I guess you can't fill over full mark on the dip stick. Any ideas on how to increase hydraulic oil volume?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 8:49pm
Does the extra tank have a big vent?        MACK
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 6:30am
Hard to make a lion out of a house cat.   If you are set on using the WD45 on the dump trailer long term I suggest you make up a self contained hyd system on the trailer and use a drive shaft to the pto.   Also there are self contained 12 volt units made for dump trailers that are pulled with a pickup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 7:56am
That's only like a 3/8 pipe fitting in bottom. Time a fitting is screwed onto it there isn't much hole left. I think oil fill thread is bigger but difficult to plumb something in there.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 8:34am
     Dad used to have a loader on the WD. The hyd. cylinders have two ports. The "power" side to lift the loader and the other side to use as an oil reservoir and plumbed to the drain hole for the hyd. reservoir on the tractor. Once the cylinders were filled with oil you had as much oil flowing back into the reservoir as you used to lift the loader. The reverse happened when lowering. No need for an additional reservoir. Did I make sense?
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 8:50am
I had the same problem, made the suction tube longer on the pump and slightly over filled the reservoir and now it lifts all the way
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 8:56am
There is prolly a one-way ram on the dump trailer, like the old trip bucket loaders
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 9:01am
Check to see if you have a vent on the extra reservoir you added. If there is none, the reservouir is air-locked and oil cant drain out because no air can get in to fill the empty space when the oil drains out. Also dont way overfill it on the factory dipstick, but you already found that out. Ideally you would have a longer horizontal reservoir mounted at the same height as the torque tube, so you wont overfill and so the pump could suck the oil into it.
www.awtractor.com
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 9:14am
[/QUOTE]
[/QUOTE]
Exactly.....these rams have no "reserve".
My Dad made a little square box reservoir for the WD.....I think that is 1/2" pipe that screws into the drain plug.
Keeping the fluid at the proper level on the dipstick keeps the fluid in the tank at the same level.
Been working great since about 1960 when he built the loader.
I use it all the time to this day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 9:31am
Here's the reservoir on my WD.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 9:43am
Make the reservoir so it uses the belt pulley hole.  I've got an aftermarket one that does that.  Dad used it as a pattern to make a bigger one.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 9:47am
AaronSEIA
In my case Dad had also built a "buzz rig" to fit on the loader arms so he still needed the belt pulley.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 9:09pm
use a diverter valve so that you are not filling the lift arm cylinders so allof it is going to the remote
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 9:06am
You really need a seperate hydraulic system for the trailer. A pto pump from a truck hoist would work. also the charlynn self contained pumps work excellent as they have the res./valves/and pump in one unit.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 6:02pm
I ran an older Woods backhoe with a oil tank, valves and one of these pto pumps.  Worked great.  The one I had was 10 gpm, but found this on ebay, which is larger, but almost identical in design.
Edited by Reindeer - 06 Mar 2019 at 6:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dooner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 8:27pm
Thanks for all the ideas. I do have a double acting ram, so I think adding another hose would be the easiest. I have the tractor in my shop, so I think I will check out adding the tank to the pulley side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 10:22am
Wow, that puts out lots of GPM for only 540 RPM.
10 GPM is the norm for most front end loaders.
This would work great on older tractors especially if they have live PTO.
