Allis Chalmers WD distributor
TractorTechLuke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TractorTechLuke Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers WD distributor
    Posted: 28 Feb 2019 at 8:48pm
So guys I’m in need of some help/parts. So I have a 1950 Allis Chalmers WD my grandpas uncle bought new. Here we are nearly 70 years later and I now own it, have restored it and take it to local shows and such. It has been converted to 12 volt with a 1 wire alternator. Now to where I need help. So at some point in it’s life the tractors Fairbanks Morse Magneto coil went out. The fix at the time for whoever decided to fix it, was to drill the hole at the top of the cap out and insert a wire from an external electric coil. This has worked for years but I’ve never thought it to run “great”. It’s kind of, well really rigged up and the coil wire can merely fall out and the engine die. So long story still very long I want to switch it to a distributor. A couple years ago at an auction I purchased a couple parts distributors. One appears to be off like a newer WD45 or something and has the solid 1 piece distributor, I think(I’ve never had mine off) that it is missing the governor weights off the end? Not sure exactly what the governor end is supposed to have on it, and pics would help. I also have a two piece distributor where it has a vertical distributor piece that mounts to a horizontal adapter plate that bolts up like the magneto does. That distributor is missing the drive that goes from the governor slotted piece that the magneto hooks up to. I am wondering if anyone has one of these drives they would sell, or some help. Thanks all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2019 at 9:26pm
We offer a rebuilt drive assy. We also offer a complete Mag to Distributor conversion if interested. Also offer Distributor rebuilding services and or exchange. Visit our website and take a look at what we offer. Be happy to help you out with anything you may need...
Steve@B&B
bb-customcircuits.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2019 at 9:27pm
Go to local tractor salvage, they should have a lot of them.        MACK
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 6:18am
Sounds to me you are not sure what you are doing, soooooo I suggest you contact Steve in NJ and get the right unit from him.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 6:46am
If you are going to tackle this yourself, do you have a parts catalog? The exploded diagrams in the ones I have are invaluable. Check ebay for used ones. But if this is new to you and you would benefit from some expert help, Steve at B&B is your guy.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 9:26am
Luke,
Your doing good. The mag sounds like it would need some repairs to be correct. Old good mags work very well. Me I like the distributor, just more used to that. So make sure you have the right one for the WD series tractor and a good parts book to cross check and you should not have much problem swapping the mag out for the distributor.
Lots of helpers on the site here. And pictures can help a lot too!
I have converted a couple from mags.
Not too bad.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 2:31pm
https://www.ebay.com/itm/Remanufactured-Distributor-Allis-Chalmers-CA-B-WC-WD-WD45-C/123668999038?hash=item1ccb3f2b7e:g:SlkAAOSw3UlceBrF:rk:14:pf:0
Click on above. This is what you need to convert to distributor from Magneto on your WD. Where ever you get it from.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 2:46pm
I am having a hard time figuring out why someone would remove the drive coupling from a distributor conversion!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 10:35pm
If it were me, I'd do it one of two ways... I'd either find a parts tractor, and get a replacement magneto, and have a worthy magneto guy give it a total rebuild and setup, and put THAT on...  if it's well cared-for... especially shedded and dry, the magneto is a self-contained ignition system that needs nothing other than motion to operate.
Or I'd find a complete distributor setup, tear it down, replace the bushing, clean up the shaft,  housing, etc., and the advance pivots, replace the springs... then fit it with a 12v Pertronix Ignitor and a matching coil.
I wouldn't go through the trouble of changing it to a distributor without going electronic trigger... good quality breaker points and condensers just don't get manufactured much anymore.  A full rebuild with electronic trigger is rock solid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 1:47pm
Well, let's see, for $15. dollars more, he could purchase one of my kits all rebuilt, with new plugs, wires, key switch, wiring and instructions. For another $130. he could buy the same kit with E.I.  Hmmmmm.....Which one would I purchase?............. Oops! Sorry. Left out the correct coil for the application to...
Steve@B&B
Edited by Steve in NJ - 02 Mar 2019 at 2:01pm
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 11:29pm
What tractors are they pulling the distributors from that will fit a WD?
 D-17?
jbirnsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 12:41am
WD45 distributer would work. I put one on the WC that I put in a Gleaner E M coded engine in.
The Gleaner E engine distributer will fit but you won’t have an oil fill hole. Can drill a hole and tap a pipe plug for one. Neighbor that that to his. There are also the distributer adapters that bolt on.
This page was generated in 0.453 seconds.
