Removing D17 Crank Pulley?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Removing D17 Crank Pulley?
    Posted: 25 Feb 2019 at 7:49pm
Looks like the front pump drive has come loose on my D17 series 2.  Is it possible to get the crank pulley off without pulling the front bolster?  It's got power steering if that makes a difference.  Can a guy get in there and drill and tap for bigger bolts?  I'd sure hate to pull the bolster.  Those power steerinlines are a booger to get back on.
AaronSEIA
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 8:12pm
You have to pull the front axle.  The pulley will not come off without a gear puller.  I don't see how you would be able to drill the holes with it on the tractor anyway.  It would be damn near impossible to get those holes lined up straight.  If you want it fixed right you can't cut corners.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 8:32pm
That's what I was afraid of.  Not looking to cut corners, just look2to see what can be done.
AaronSEIA
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 10:04pm
AaronSEIA
Aaron, you might pull the radiator, front pump and turn the pulley to the point one of the four bolt holes is up come through the front pump cutout in the bolster with using a long drill bit re-drill the four holes out and rethread then one at a time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2019 at 6:24am
Thats an idea.  I'll have to pull the rad and go from there.
AaronSEIA
This page was generated in 0.035 seconds.
