Rebuilt Engines
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Topic: Rebuilt Engines
    Posted: 04 Feb 2019 at 5:22pm
I am looking at starting back on an old tractor that has been sitting at my shop several years. It is a 185 that needs an engine rebuild. Back several years ago I thought it would be about a cheap to buy an already built short block as to rebuild the engine myself. Well not exactly but worth the difference in cost for the ease of the project.
It looks like that is not true anymore unless someone can give me a good engine resource. Any comments would be appreciated.
I may just build it myself. I've build several smaller engines for lower horsepower D-series tractors , but they were all gas burners.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2019 at 8:52pm
Make sure you have an Allis service manual for the 185, not I&T.  They are quite a bit different than the gassers.  See if there any retired mechanics in your area that want a project to work on.  The guy I get to rebuild my engines is more than reasonable, he likes having things to work on.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2019 at 6:11am
Proper valve and seat grinding is very important in a diesel. The valves have to standout the same height across the head and to a certain spec. Sleeve standout is important too so you won't blow a head gasket.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 11:49am
My dad and uncle ran an AC dealership in the 60's, so I have real AC shop manuals.
My dad use to say a diesel was a harder build. I bought the 185 before he passed. We were going to rebuild it together. Now he'll just be smiling down.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 11:56am
My grandpa overhauled a diesel once, and it was the only one he ever did. He rebuilt countless gasoline engines, but he did say the diesel was challenging. Ran good when he finally finished, though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 11:56am
Liner protrusion HAS to be equal across the deck on these with a single head, There are nuances to any engine where these are pretty sensitive.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 3:53pm
could you even find a short block for that nowadays ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 3:58pm
Im with DSeriers4 ............. look around for a local guy or shop that does diesels and rebuild yours.
