D-17 series II power steering issue
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: D-17 series II power steering issue
    Posted: 31 Jan 2019 at 6:35am
D-17 series II factory power steering with distributor driven pump.  Power steering works, but seems weak and I know it isnt working as good as it should.  Fluid is full with universal trans/hydraulic.  What should I start checking?  Thanks!
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 7:15am
Wornout pump or control valve needs readjusted.       MACK
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 7:21am
How cold is it?   Mine all but quits working when it's cold out.  I'm a moron and put 303 in it though.  I've heard that you can use ATF and it isn't as affected by the cold.  5-10 minutes of warming up and I'm usually good to go.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 7:50am
I have a factory service manual, I will check out the control valve. Any advice on adjusting it MACK?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 9:21pm
The AC service manual has the steps and torque. Be sure to put in all new orings.MACK
