I;m the guilty one
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Topic: I;m the guilty one
    Posted: 28 Jan 2019 at 10:13pm
for coming in here and starting a discussion on oil then leaving for ya'll to bicker about it but this time I gort a legit question.
Is it ok to use a grease on my wheel bearing on my truck, a grease containing polytetgraflouroethylene?
I still gots my A/C but it's clear out in the barn now.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 10:24pm
Les, first you are gonna have to tell us what polytetgraflouroethylene is..
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 10:29pm
sorry John. Didn't mean to slide that one on by ya, but I miss spelled it. Here ya go.
polytetraflouroethylene
If'n ya still don't know, here's a hint.
It was discovered in 1938
Edited by Les Royer - 28 Jan 2019 at 10:31pm
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 11:29pm
Hint #2 Dupont.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 6:11am
It's PTFE which is Teflon. Use it if you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 6:25am
Slick 50  Good Stuff
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 6:44am
It works nicely on cookware. As a motor oil additive, not so much.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 11:30am
Vehicles equipped with disc/drum brake wheel bearings recommend a higher temperature grease viscosity.
NLGI -GCLB is the recommenced standard for such higher temperature applications.
So the question becomes, does your PTFE accomplish a NLGI - GCLB standard?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 7:38pm
dunno. My owners manual says to use hub lock grease on the lockouts and long life premium grease on the wheel bearings. So now we got two different grease types in the same cavity. Didn't think that was recommended.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 7:36am
Didn't you listen to your mother???  Just DO AS YOU'RE TOLD...
Couldn't resist buddy.
The lock outs require a thinner grease so that in cold weather they are able to turn somewhat easily.  With the weather we have right now, I doubt you'll be turning anything!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 8:04am
are you STILL working on them old worn out truck wanna-be's? whew! and what's wrong with using what the owners manual says to use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 5:58pm
I think the main NO-NO is to not mix the bases, of the grease. that would be like mixing a sodium base with a lithium base, or a calcium base...Wink
